    2. ezequiel.rebasa
    E
    • Topics 1
    • Posts 3
    • Best 0
    Posts made by ezequiel.rebasa
    • RE: Unable to Obtain Tenant-Signed Access Token for Data-Plane Apps in a Multi-Client, Multi-Application FusionAuth Architecture
      @mark-robustelli Hello, thanks so much for sharing your approach and the detailed setup.
      In our case, we haven’t been able to implement it because we’re running FusionAuth Free in a Docker container, and testing the Lambda HTTP Connect functionality (which requires an Essentials or Enterprise plan) would mean spinning up a second Docker instance with the Enterprise edition just to try it out—and that’s too much overhead for our current environment. We had also tried adding the context-tenant claims and using the IdP’s token, but it’s apparent that those options only work in the Enterprise version.
      We appreciate your guidance and hope we can find a workable workaround to get this resolved in our setup soon.
      posted in Q&A
      E
      ezequiel.rebasa
      @mark-robustelli
      Thank you Mark for responding and I would like to take this opportunity to provide more clarity on what we have implemented and what we want to achieve.
      Use Case: Hybrid SSO Across Physically Isolated Tenants
      We maintain N physically isolated FusionAuth tenants (each with its own database) and within each tenant multiple Applications. Instead of provisioning the same email in every tenant, we have a single “Control-Plane” tenant called Simfinix, where each user logs in exactly once.
      Our backend enriches each FusionAuth user record with a custom field, user.data.tenants, listing which physical tenants and which Applications in those tenants they’re allowed to access. When a user switches context, the backend is supposed to silently obtain a new access token signed by that specific tenant’s FusionAuth instance and scoped to the chosen Application—no re-login required.
      However, at present we are unable to achieve this. When we call /api/jwt/issue on the target tenant, FusionAuth looks for the Application Portal-Simfinix (which only exists in the Simfinix tenant) and returns “application not found,” so we never receive a token signed by the intended tenant-context.
      Topology Example:
      yaml
      Copy
      Edit
      Tenants
      ├── Simfinix (OIDC IdP)
      │ └── Apps: Portal-Simfinix (identity provider)
      ├── TenantA
      │ └── Apps: AppA, AppB, AppC
      └── TenantB
      User: xxx@gmail.com
      ├── authenticatedTenant: Simfinix
      └── user.data.tenants (custom FusionAuth field):
      tenantId: TenantA_ID,
      applications: [AppA_ID, AppC_ID]
      tenantId: TenantB_ID,
      applications: [AppB_ID]
      Key Points:
      Single login in Simfinix → backend stores one refresh_token_simfinix.
      Silent-login flow per tenant: backend uses that token to perform an OIDC authorize request with prompt=none in the target tenant and exchanges the code for refresh_token and access_token issued by that tenant.
      A call to /api/jwt/issue or a refresh_token grant against the chosen tenant should issue a JWT signed by that tenant and scoped to the selected Application.
      Current blocker: FusionAuth is searching for “Portal-Simfinix” in the target tenant’s Applications (because that’s the client_id we’re passing) and fails with “application not found,” so we never get the tenant-signed JWT.
      Once resolved, users will experience “log in once → switch anywhere,” with each tenant remaining fully isolated and all tokens correctly signed by the appropriate tenant.
      Note: the property user.data.tenants lives on the FusionAuth User object (under its data map) and is fully custom—FusionAuth doesn’t provide it out-of-the-box, but we extend the User entity to include it.
      posted in Q&A
      E
      ezequiel.rebasa
    • Unable to Obtain Tenant-Signed Access Token for Data-Plane Apps in a Multi-Client, Multi-Application FusionAuth Architecture
      Our architecture breaks a bit with how FusionAuth approaches multitenancy.
      Because Fusion is designed (or at least that's how I see it) to be a multi-application tenant, allowing for switching between applications within the same tenant.
      We are implementing OIDC and have one tenant with one application that will be our identity provider and sole means of authentication. A user can belong to N tenants with N applications, but their login is through that Simfinix tenant (IDP).
      Once logged in, it allows me to switch between different tenants. But the complexity is in token management, since Fusion can return the token signed by Simfinix, and with a Lambda, I can add any claims I want. However, when selecting a contextualized tenant, it doesn't allow me to create a token signed by that tenant to ensure no one can modify the tenant I'm currently working with.
      Is this clear?
      Could you help us find a solution?
      We are considering manually managing the tokens, but we are not sure if we are leaving any security holes. We would also prefer FusionAuth to handle this, also because of the possibility of refresh tokens.
      posted in Q&A
      E
      ezequiel.rebasa
