Hi Dan,
Thx for the response - correct, re the login form, and adding a captcha solution.
J
Posts made by j.frost
RE: Captch solution with FusionAuthposted in Q&A
Is there an option to use a captch solution with FusionAuth / plugin looks to only support password encryption. Are there any examples to view?
