    2. john.mooney
    J
    • Topics 3
    • Posts 3
    • Best 0
    Posts made by john.mooney
    • JWT Populate Lambda and Application properties
      Hello I would like to be able to access the Application Properties in a JWT Populate Lambda.
      I see JWT, User and Registration are parameters but is it possible to somehow get to the Application properties?
      Thanks
      posted in Q&A
      J
      john.mooney
    • Issue with FA 1.25 Database Connections
      Hi All,
      I have FusionAuth setup in an Azure App Service. It is setup with a Docker Container using the official Docker Hub image fusionauth/fusionauth-app:1.25.0
      This error is happening probably every few hours and we have to rebuild the container and start the service again.
      The database is on a PostgreSQL server on Azure on a Gen 5 Compute with 2 vCores and 100GB of storage which is plenty for a dev system that get lightly used.
      Here is the error that keeps coming up. Does anyone have any ideas why this keeps happening?
      This is becoming a major issue as we are wanting to go live in the next couple of months.
      2021-03-24T21:35:35 No new trace in the past 1 min(s).
      2021-03-24T21:35:30.393197544Z 2021-03-24 9:35:30.391 PM ERROR io.fusionauth.app.primeframework.error.ExceptionExceptionHandler - An unhandled exception was thrown
      2021-03-24T21:35:30.393245145Z com.google.inject.ProvisionException: Unable to provision, see the following errors:
      2021-03-24T21:35:30.393257845Z
      2021-03-24T21:35:30.393266746Z 1) Error injecting constructor, org.apache.ibatis.exceptions.PersistenceException:
      2021-03-24T21:35:30.393275746Z ### Error querying database. Cause: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2000ms.
      2021-03-24T21:35:30.393298646Z ### The error may exist in io/fusionauth/api/domain/TenantMapper.xml
      2021-03-24T21:35:30.393306447Z ### The error may involve io.fusionauth.api.domain.TenantMapper.retrieveAll
      2021-03-24T21:35:30.393314247Z ### The error occurred while executing a query
      2021-03-24T21:35:30.393321847Z ### Cause: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2000ms.
      2021-03-24T21:35:30.393329247Z at io.fusionauth.app.action.oauth2.AuthorizeAction.<init>(AuthorizeAction.java:59)
      2021-03-24T21:35:30.393337047Z while locating io.fusionauth.app.action.oauth2.AuthorizeAction
      2021-03-24T21:35:30.393344448Z
      2021-03-24T21:35:30.393351648Z 1 error
      2021-03-24T21:35:30.393359048Z at com.google.inject.internal.InternalProvisionException.toProvisionException(InternalProvisionException.java:226)
      2021-03-24T21:35:30.393366848Z at com.google.inject.internal.InjectorImpl$1.get(InjectorImpl.java:1097)
      2021-03-24T21:35:30.393374448Z at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1131)
      2021-03-24T21:35:30.393382049Z at org.primeframework.mvc.action.DefaultActionMapper.map(DefaultActionMapper.java:61)
      2021-03-24T21:35:30.393389849Z at org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:92)
      2021-03-24T21:35:30.393397249Z at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:51)
      2021-03-24T21:35:30.393404949Z at org.primeframework.mvc.workflow.StaticResourceWorkflow.perform(StaticResourceWorkflow.java:97)
      2021-03-24T21:35:30.393412549Z at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:51)
      2021-03-24T21:35:30.393419250Z at org.primeframework.mvc.parameter.RequestBodyWorkflow.perform(RequestBodyWorkflow.java:89)
      2021-03-24T21:35:30.393426450Z at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:51)
      2021-03-24T21:35:30.393434150Z at org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:64)
      2021-03-24T21:35:30.393443250Z at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:51)
      2021-03-24T21:35:30.393450750Z at io.fusionauth.app.primeframework.CORSFilter.doFilter(CORSFilter.java:262)
      2021-03-24T21:35:30.393457651Z at io.fusionauth.app.primeframework.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:49)
      2021-03-24T21:35:30.393464351Z at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:51)
      2021-03-24T21:35:30.393471151Z at io.fusionauth.app.primeframework.FusionAuthMVCWorkflow.perform(FusionAuthMVCWorkflow.java:88)
      2021-03-24T21:35:30.393478351Z at org.primeframework.mvc.workflow.DefaultWorkflowChain.continueWorkflow(DefaultWorkflowChain.java:44)
      2021-03-24T21:35:30.393485151Z at org.primeframework.mvc.servlet.FilterWorkflowChain.continueWorkflow(FilterWorkflowChain.java:50)
      2021-03-24T21:35:30.393498152Z at org.primeframework.mvc.servlet.PrimeFilter.doFilter(PrimeFilter.java:78)
      2021-03-24T21:35:30.393505452Z at com.inversoft.maintenance.servlet.MaintenanceModePrimeFilter.doFilter(MaintenanceModePrimeFilter.java:59)
      2021-03-24T21:35:30.393512152Z at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
      2021-03-24T21:35:30.393519252Z at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
      2021-03-24T21:35:30.393526252Z at com.inversoft.servlet.UTF8Filter.doFilter(UTF8Filter.java:27)
      2021-03-24T21:35:30.393533253Z at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
      2021-03-24T21:35:30.393539953Z at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
      2021-03-24T21:35:30.393546553Z at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
      2021-03-24T21:35:30.393553353Z at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
      2021-03-24T21:35:30.393575654Z at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
      2021-03-24T21:35:30.393582554Z at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
      2021-03-24T21:35:30.393589554Z at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
      2021-03-24T21:35:30.393596054Z at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
      2021-03-24T21:35:30.393602954Z at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:353)
      2021-03-24T21:35:30.393609855Z at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:616)
      2021-03-24T21:35:30.393616855Z at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
      2021-03-24T21:35:30.393624355Z at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
      2021-03-24T21:35:30.393631355Z at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1629)
      2021-03-24T21:35:30.393638255Z at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
      2021-03-24T21:35:30.393645055Z at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
      2021-03-24T21:35:30.393651956Z at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
      2021-03-24T21:35:30.393658856Z at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
      2021-03-24T21:35:30.393665756Z at java.base/java.lang.Thread.run(Thread.java:832)
      2021-03-24T21:35:30.393672556Z Caused by: org.apache.ibatis.exceptions.PersistenceException:
      2021-03-24T21:35:30.393679456Z ### Error querying database. Cause: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2000ms.
      2021-03-24T21:35:30.393691957Z ### The error may exist in io/fusionauth/api/domain/TenantMapper.xml
      2021-03-24T21:35:30.393698857Z ### The error may involve io.fusionauth.api.domain.TenantMapper.retrieveAll
      2021-03-24T21:35:30.393705557Z ### The error occurred while executing a query
      2021-03-24T21:35:30.393712057Z ### Cause: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2000ms.
      2021-03-24T21:35:30.393718857Z at org.apache.ibatis.exceptions.ExceptionFactory.wrapException(ExceptionFactory.java:30)
      2021-03-24T21:35:30.393725458Z at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:149)
      2021-03-24T21:35:30.393732358Z at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:140)
      2021-03-24T21:35:30.393739158Z at jdk.internal.reflect.GeneratedMethodAccessor60.invoke(Unknown Source)
      2021-03-24T21:35:30.393745958Z at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
      2021-03-24T21:35:30.393752658Z at java.base/java.lang.reflect.Method.invoke(Method.java:564)
      2021-03-24T21:35:30.393769759Z at org.apache.ibatis.session.SqlSessionManager$SqlSessionInterceptor.invoke(SqlSessionManager.java:357)
      2021-03-24T21:35:30.393773459Z at com.sun.proxy.$Proxy46.selectList(Unknown Source)
      2021-03-24T21:35:30.393777159Z at org.apache.ibatis.session.SqlSessionManager.selectList(SqlSessionManager.java:206)
      2021-03-24T21:35:30.393780859Z at org.apache.ibatis.binding.MapperMethod.executeForMany(MapperMethod.java:147)
      2021-03-24T21:35:30.393784559Z at org.apache.ibatis.binding.MapperMethod.execute(MapperMethod.java:80)
      2021-03-24T21:35:30.393788659Z at org.apache.ibatis.binding.MapperProxy.invoke(MapperProxy.java:93)
      2021-03-24T21:35:30.393792459Z at com.sun.proxy.$Proxy63.retrieveAll(Unknown Source)
      2021-03-24T21:35:30.393796159Z at io.fusionauth.api.service.system.DefaultTenantService.retrieveAll(DefaultTenantService.java:220)
      2021-03-24T21:35:30.393799960Z at io.fusionauth.app.action.BaseThemedAction.<init>(BaseThemedAction.java:89)
      2021-03-24T21:35:30.393803860Z at io.fusionauth.app.action.oauth2.BaseOAuthAction.<init>(BaseOAuthAction.java:149)
      2021-03-24T21:35:30.393807560Z at io.fusionauth.app.action.oauth2.AuthorizeAction.<init>(AuthorizeAction.java:59)
      2021-03-24T21:35:30.393811360Z at io.fusionauth.app.action.oauth2.AuthorizeAction$$FastClassByGuice$$c726b99d.newInstance(<generated>)
      2021-03-24T21:35:30.393815460Z at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89)
      2021-03-24T21:35:30.393819260Z at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
      2021-03-24T21:35:30.393822960Z at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91)
      2021-03-24T21:35:30.393826660Z at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
      2021-03-24T21:35:30.393833860Z at com.google.inject.internal.InjectorImpl$1.get(InjectorImpl.java:1094)
      2021-03-24T21:35:30.393837660Z ... 39 common frames omitted
      2021-03-24T21:35:30.393841361Z Caused by: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2000ms.
      2021-03-24T21:35:30.393845161Z at com.zaxxer.hikari.pool.HikariPool.createTimeoutException(HikariPool.java:697)
      2021-03-24T21:35:30.393848861Z at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:196)
      2021-03-24T21:35:30.393852761Z at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:161)
      2021-03-24T21:35:30.393856561Z at com.zaxxer.hikari.HikariDataSource.getConnection(HikariDataSource.java:100)
      2021-03-24T21:35:30.393860261Z at org.apache.ibatis.transaction.jdbc.JdbcTransaction.openConnection(JdbcTransaction.java:138)
      2021-03-24T21:35:30.393863961Z at org.apache.ibatis.transaction.jdbc.JdbcTransaction.getConnection(JdbcTransaction.java:60)
      2021-03-24T21:35:30.393867661Z at org.apache.ibatis.executor.BaseExecutor.getConnection(BaseExecutor.java:336)
      2021-03-24T21:35:30.393871261Z at org.apache.ibatis.executor.SimpleExecutor.prepareStatement(SimpleExecutor.java:86)
      2021-03-24T21:35:30.393874961Z at org.apache.ibatis.executor.SimpleExecutor.doQuery(SimpleExecutor.java:62)
      2021-03-24T21:35:30.393878662Z at org.apache.ibatis.executor.BaseExecutor.queryFromDatabase(BaseExecutor.java:324)
      2021-03-24T21:35:30.393882662Z at org.apache.ibatis.executor.BaseExecutor.query(BaseExecutor.java:156)
      2021-03-24T21:35:30.393886362Z at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:109)
      2021-03-24T21:35:30.393890062Z at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:83)
      2021-03-24T21:35:30.393893662Z at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:147)
      2021-03-24T21:35:30.393897462Z ... 60 common frames omitted
      2021-03-24T21:35:30.393900962Z Caused by: org.postgresql.util.PSQLException: This connection has been closed.
      2021-03-24T21:35:30.393904562Z at org.postgresql.jdbc.PgConnection.checkClosed(PgConnection.java:865)
      2021-03-24T21:35:30.393908262Z at org.postgresql.jdbc.PgConnection.setNetworkTimeout(PgConnection.java:1647)
      2021-03-24T21:35:30.393911962Z at com.zaxxer.hikari.pool.PoolBase.setNetworkTimeout(PoolBase.java:552)
      2021-03-24T21:35:30.393915563Z at com.zaxxer.hikari.pool.PoolBase.isConnectionAlive(PoolBase.java:168)
      2021-03-24T21:35:30.393919163Z at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:185)
      2021-03-24T21:35:30.393922863Z at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:161)
      2021-03-24T21:35:30.393926463Z at com.zaxxer.hikari.HikariDataSource.getConnection(HikariDataSource.java:100)
      2021-03-24T21:35:30.393933063Z at org.apache.ibatis.transaction.jdbc.JdbcTransaction.openConnection(JdbcTransaction.java:138)
      2021-03-24T21:35:30.393936963Z at org.apache.ibatis.transaction.jdbc.JdbcTransaction.getConnection(JdbcTransaction.java:60)
      2021-03-24T21:35:30.393940763Z at org.apache.ibatis.executor.BaseExecutor.getConnection(BaseExecutor.java:336)
      2021-03-24T21:35:30.393944463Z at org.apache.ibatis.executor.SimpleExecutor.prepareStatement(SimpleExecutor.java:86)
      2021-03-24T21:35:30.393948063Z at org.apache.ibatis.executor.SimpleExecutor.doQuery(SimpleExecutor.java:62)
      2021-03-24T21:35:30.393951763Z at org.apache.ibatis.executor.BaseExecutor.queryFromDatabase(BaseExecutor.java:324)
      2021-03-24T21:35:30.393955464Z at org.apache.ibatis.executor.BaseExecutor.query(BaseExecutor.java:156)
      2021-03-24T21:35:30.393959064Z at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:109)
      2021-03-24T21:35:30.393962764Z at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:83)
      2021-03-24T21:35:30.393966464Z at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:147)
      2021-03-24T21:35:30.393970164Z at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:140)
      2021-03-24T21:35:30.393973864Z at org.apache.ibatis.session.defaults.DefaultSqlSession.selectOne(DefaultSqlSession.java:76)
      2021-03-24T21:35:30.393977864Z at jdk.internal.reflect.GeneratedMethodAccessor47.invoke(Unknown Source)
      2021-03-24T21:35:30.393981564Z at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
      2021-03-24T21:35:30.393985364Z at java.base/java.lang.reflect.Method.invoke(Method.java:564)
      2021-03-24T21:35:30.393988964Z at org.apache.ibatis.session.SqlSessionManager$SqlSessionInterceptor.invoke(SqlSessionManager.java:357)
      2021-03-24T21:35:30.393992765Z at com.sun.proxy.$Proxy46.selectOne(Unknown Source)
      2021-03-24T21:35:30.393996365Z at org.apache.ibatis.session.SqlSessionManager.selectOne(SqlSessionManager.java:166)
      2021-03-24T21:35:30.393999965Z at org.apache.ibatis.binding.MapperMethod.execute(MapperMethod.java:87)
      2021-03-24T21:35:30.394003665Z at org.apache.ibatis.binding.MapperProxy.invoke(MapperProxy.java:93)
      2021-03-24T21:35:30.394007265Z at com.sun.proxy.$Proxy54.retrieve(Unknown Source)
      2021-03-24T21:35:30.394010965Z at io.fusionauth.api.service.cache.SystemConfigurationCacheLoader.internalLoad(SystemConfigurationCacheLoader.java:43)
      2021-03-24T21:35:30.394014665Z at com.inversoft.cache.BaseCacheLoader.load(BaseCacheLoader.java:21)
      2021-03-24T21:35:30.394018365Z at io.fusionauth.api.service.cache.SystemConfigurationCacheLoader.run(SystemConfigurationCacheLoader.java:38)
      2021-03-24T21:35:30.394022065Z at com.inversoft.scheduler.InjectableRunnable.run(InjectableRunnable.java:37)
      2021-03-24T21:35:30.394025765Z at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
      2021-03-24T21:35:30.394032466Z at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
      2021-03-24T21:35:30.394036266Z at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
      2021-03-24T21:35:30.394040066Z at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
      2021-03-24T21:35:30.394043766Z at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
      2021-03-24T21:35:30.394047566Z ... 1 common frames omitted
      2021-03-24T21:35:30.394051066Z 2021-03-24 9:35:30.392 PM ERROR org.primeframework.mvc.servlet.PrimeFilter - Error encountered
      2021-03-24T21:35:30.394054766Z java.lang.NullPointerException: null
      2021-03-24T21:35:30.394058366Z at org.primeframework.mvc.message.l10n.ResourceBundleMessageProvider.findMessage(ResourceBundleMessageProvider.java:129)
      2021-03-24T21:35:30.394062166Z at org.primeframework.mvc.message.l10n.ResourceBundleMessageProvider.getOptionalMessage(ResourceBundleMessageProvider.java:88)
      2021-03-24T21:35:30.394065966Z at org.primeframework.mvc.message.l10n.ResourceBundleMessageProvider.getMessage(ResourceBundleMessageProvider.java:76)
      2021-03-24T21:35:30.394070067Z at io.fusionauth.app.primeframework.error.ExceptionExceptionHandler.handle(ExceptionExceptionHandler.java:48)
      2021-03-24T21:35:30.394073967Z at io.fusionauth.app.primeframework.error.ExceptionExceptionHandler.handle(ExceptionExceptionHandler.java:22)
      2021-03-24T21:35:30.394077667Z at org.primeframework.mvc.workflow.DefaultExceptionHandler.handle(DefaultExceptionHandler.java:39)
      2021-03-24T21:35:30.394081467Z at io.fusionauth.app.primeframework.FusionAuthMVCWorkflow.perform(FusionAuthMVCWorkflow.java:90)
      2021-03-24T21:35:30.394085167Z at org.primeframework.mvc.workflow.DefaultWorkflowChain.continueWorkflow(DefaultWorkflowChain.java:44)
      2021-03-24T21:35:30.394088867Z at org.primeframework.mvc.servlet.FilterWorkflowChain.continueWorkflow(FilterWorkflowChain.java:50)
      2021-03-24T21:35:30.394092567Z at org.primeframework.mvc.servlet.PrimeFilter.doFilter(PrimeFilter.java:78)
      2021-03-24T21:35:30.394096267Z at com.inversoft.maintenance.servlet.MaintenanceModePrimeFilter.doFilter(MaintenanceModePrimeFilter.java:59)
      2021-03-24T21:35:30.394099967Z at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
      2021-03-24T21:35:30.394103667Z at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
      2021-03-24T21:35:30.394107468Z at com.inversoft.servlet.UTF8Filter.doFilter(UTF8Filter.java:27)
      2021-03-24T21:35:30.394111068Z at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
      2021-03-24T21:35:30.394114868Z at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
      2021-03-24T21:35:30.394118568Z at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
      2021-03-24T21:35:30.394125068Z at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
      2021-03-24T21:35:30.394128868Z at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
      2021-03-24T21:35:30.394132568Z at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
      2021-03-24T21:35:30.394136268Z at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
      2021-03-24T21:35:30.394139968Z at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
      2021-03-24T21:35:30.394143569Z at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:353)
      2021-03-24T21:35:30.394147269Z at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:616)
      2021-03-24T21:35:30.394150969Z at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
      2021-03-24T21:35:30.394154969Z at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
      2021-03-24T21:35:30.394158669Z at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1629)
      2021-03-24T21:35:30.394162369Z at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
      2021-03-24T21:35:30.394166069Z at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
      2021-03-24T21:35:30.394169769Z at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
      2021-03-24T21:35:30.394173469Z at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
      2021-03-24T21:35:30.394177169Z at java.base/java.lang.Thread.run(Thread.java:832)
      posted in Q&A
      J
      john.mooney
    • User Enumeration
      Hello, I was wondering if FusionAuth will mitigate User Enumeration attacks by apply some random response delay or any other method?
      posted in General Discussion
      J
      john.mooney
