Posts made by jw 0
RE: React SDK example - nothing in the userInfo but tid and subposted in General Discussion
If I do this:
<RequireAuth withRole="owner">
I am the owner!
</RequireAuth>I don't see anything displayed on the page even though my login has the owner role.
I've also go the following on the page:
<p>roles {userInfo?.roles}</p>And this is always empty.
If I look at the network call to /me in Chrome devtools I see this:{
"email": "jason@",
"email_verified": true,
"family_name": "Last",
"given_name": "First",
"locale": "af",
"middle_name": "Middle",
"name": "Jason Test customer owner",
"preferred_username": "jason@",
"sub": "26ffd6b7-cbb3-4234-9a16-5ad8b7d6c6bc",
"tid": "03c94007-732e-48f4-88c4-d53e5a777e47",
"zoneinfo": "Africa/Abidjan"
}Looking at the SDK source the code seems to simply turn this into the JS userInfo object so it looks like the roles will never be set
Thanks @mark-robustelli - it was just I hadn't included the scopes!
I can see everything I want in the userInfo structure other than the roles.
Is this something I have to do manually? I've looked at the JS SDK code and it seems to be only giving me what comes back in the call to /meHowever, they are in the JWT as I'd expect
"aud": "3c219e58-ed0e-4b18-ad48-f4f92793ae32",
"exp": 1724955478,
"iat": 1724955418,
"iss": "localhost:9011",
"sub": "75359739-1fb2-4f64-9116-37f67a47a231",
"jti": "6c1935e3-0428-4a09-8651-849e1140fe04",
"authenticationType": "REFRESH_TOKEN",
"roles": [
"admin"
"auth_time": 1724954534,
"scope": "offline_access",
"applicationId": "3c219e58-ed0e-4b18-ad48-f4f92793ae32",
"tid": "188a3b31-5d90-bbf8-75dc-94b9e004b1ba",
"sid": "aed93b0a-b993-4fde-98f9-8b274b723dde"
I'm sure I'm doing something stupid here but I can't work out what I haven't done.
I am using the changebank React SDK example as my test harness, using the community version of FusionAuth for now, hosted under docker
I've created a new tenant, a new app and then a new user.
I can login using this new user into the app but the userInfo structure has nothing in it other the the use sub and the tid.Config is below
const config: FusionAuthProviderConfig = {
clientId: "31067471-23fc-4634-afa9-c049ff4f0a86",
redirectUri: "http://localhost:5173",
serverUrl: "http://localhost:9011/",
shouldAutoFetchUserInfo: true,
shouldAutoRefresh: true,
onRedirect: (state?: string) => {
console.log(Redirect happened with state value: ${state}"});
};Example code is:
In main.tsx
const { isLoggedIn, isFetchingUserInfo, userInfo } = useFusionAuth();In the AccountPage.tsx I have:
<p>tid {userInfo?.tid}</p> <p>sub {userInfo?.sub}</p> <p>roles {userInfo?.roles}</p> <p>email {userInfo?.email}</p>The roles and email fields are always null
Any ideas?
