    2. manuel.voss
    M
    • Topics 1
    • Posts 1
    • Best 0
    Posts made by manuel.voss
    • Systemd service template
      Hi everybody. 🙂
      I managed to install FusionAuth on Ubuntu. Went by the official guides and ran
      sh -c "curl -fsSL https://raw.githubusercontent.com/FusionAuth/fusionauth-install/master/install.sh | sh -s - -z"
      Taken from https://fusionauth.io/download/.
      This properly installed FusionAuth. After some fiddling around with the database setup, I can now run /var/lib/fusionauth/bin/startup.sh and FusionAuth will be up and running.
      According to the documentation, services for systemd should have been installed, but that somehow didn't happen. So I can't call systemctl start fusionauth-app, also there is no file at /etc/init.d/fusionauth-app.
      In order to still have FA running as a service, I created a quick systemd service configuration:
      [Unit]
      Description=FusionAuth
      [Service]
      Type=forking
      ExecStart=/var/lib/fusionauth/bin/startup.sh
      [Install]
      WantedBy=multi-user.target
      Sadly, this doesn't work. Does anyone have a working service definition or are there some templates?
      posted in General Discussion
      M
      manuel.voss
