Hi,
I tried to get as much as possible on logs and this is all i can get
NOTE: Picked up JDK_JAVA_OPTIONS:  --add-opens=java.base/java.lang=ALL-UNNAMED -
-add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=
ALL-UNNAMED
24-Jul-2020 15:37:49.580 WARNING [main] org.apache.catalina.startup.SetAllProper
tiesRule.begin [SetAllPropertiesRule]{Server/Service/Connector} Setting property
 'maxHttpHeaderSize' to '${fusionauth.http.max.header-size}' did not find a matc
hing property.
24-Jul-2020 15:37:49.674 WARNING [main] org.apache.catalina.startup.SetAllProper
hing property.
24-Jul-2020 15:37:49.940 INFO [main] org.apache.catalina.core.AprLifecycleListen
er.lifecycleEvent The APR based Apache Tomcat Native library which allows optima
l performance in production environments was not found on the java.library.path:
 [C:\MFA\java\jdk-14.0.1+7\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Wi
ndows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System3
2\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Skype\Phone\;C:\Program Files\M
icrosoft\Web Platform Installer\;C:\Program Files\MySQL\MySQL Server 5.5\bin;.]
24-Jul-2020 15:37:50.971 INFO [main] org.apache.coyote.AbstractProtocol.init Ini
tializing ProtocolHandler ["http-nio-9011"]
24-Jul-2020 15:37:51.127 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.
getSharedSelector Using a shared selector for servlet write/read
24-Jul-2020 15:37:51.174 INFO [main] org.apache.coyote.AbstractProtocol.init Ini
tializing ProtocolHandler ["https-jsse-nio-9013"]
24-Jul-2020 15:37:51.924 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.
24-Jul-2020 15:37:51.940 INFO [main] org.apache.coyote.AbstractProtocol.init Ini
tializing ProtocolHandler ["ajp-nio-127.0.0.1-9019"]
24-Jul-2020 15:37:51.940 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.
24-Jul-2020 15:37:51.955 INFO [main] org.apache.catalina.startup.Catalina.load I
nitialization processed in 2903 ms
24-Jul-2020 15:37:51.971 INFO [main] org.apache.catalina.core.StandardService.st
artInternal Starting service [Catalina]
24-Jul-2020 15:37:51.971 INFO [main] org.apache.catalina.core.StandardEngine.sta
rtInternal Starting Servlet Engine: Apache Tomcat/8.5.53
Jul 24, 2020 3:37:57 PM org.apache.jasper.servlet.TldScanner scanJars
INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug
logging for this logger for a complete list of JARs that were scanned but no TLD
s were found in them. Skipping unneeded JARs during scanning can improve startup
 time and JSP compilation time.
Jul 24, 2020 3:37:59.065 pm INFO  io.fusionauth.api.configuration.PropertiesFile
FusionAuthConfiguration - Loading FusionAuth configuration file [C:\MFA\config\f
usionauth.properties]
Jul 24, 2020 3:37:59.174 pm INFO  io.fusionauth.api.configuration.PropertiesFile
FusionAuthConfiguration - Dynamically set property [fusionauth-app.url] set to [
http://10.250.118.35:9011]
Jul 24, 2020 3:37:59.190 pm INFO  io.fusionauth.api.configuration.PropertiesFile
FusionAuthConfiguration - Set Max HTTP header size to [8192].
Jul 24, 2020 3:38:01.549 pm INFO  io.fusionauth.api.configuration.PropertiesFile
Jul 24, 2020 3:38:01.627 pm INFO  io.fusionauth.api.configuration.PropertiesFile
Jul 24, 2020 3:38:01.690 pm INFO  io.fusionauth.api.configuration.PropertiesFile
Jul 24, 2020 3:38:01.768 pm INFO  io.fusionauth.api.configuration.PropertiesFile
Jul 24, 2020 3:38:02.955 pm INFO  io.fusionauth.app.maintenance.FusionAuthMainte
nanceModeWorkflow - Determine database status : DOWN
Jul 24, 2020 3:38:02.955 pm INFO  org.primeframework.mvc.servlet.PrimeServletCon
textListener - Initializing Prime
Jul 24, 2020 3:38:02.955 pm INFO  io.fusionauth.app.maintenance.guice.FusionAuth
MaintenanceModeModule -
--------------------------------------- Entering Maintenance Mode --------------
Jul 24, 2020 3:38:03.205 pm INFO  io.fusionauth.api.configuration.PropertiesFile
Jul 24, 2020 3:38:03.283 pm INFO  io.fusionauth.api.configuration.PropertiesFile
Jul 24, 2020 3:38:03.283 pm INFO  com.inversoft.maintenance.MaintenanceModePolle
r - Poller started to Wait for configuration to be completed.
24-Jul-2020 15:38:03.393 INFO [main] org.apache.coyote.AbstractProtocol.start St
arting ProtocolHandler ["http-nio-9011"]
24-Jul-2020 15:38:03.424 INFO [main] org.apache.coyote.AbstractProtocol.start St
arting ProtocolHandler ["https-jsse-nio-9013"]
24-Jul-2020 15:38:03.440 INFO [main] org.apache.coyote.AbstractProtocol.start St
arting ProtocolHandler ["ajp-nio-127.0.0.1-9019"]
24-Jul-2020 15:38:03.440 INFO [main] org.apache.catalina.startup.Catalina.start
Server startup in 11490 ms
  applications_id            BINARY(16) NOT NULL,
  clean_speak_application_id BINARY(16) NOT NULL,
  CONSTRAINT clean_speak_applications_fk_1 FOREIGN KEY (applications_id) REFEREN
CES applications(id),
  CONSTRAINT clean_speak_applications_uk_1 UNIQUE (applications_id, clean_speak_
application_id)
  ENGINE = innodb
  CHARACTER SET utf8mb4
  COLLATE utf8mb4_bin;
CREATE TABLE application_roles (
  description         VARCHAR(255) NULL,
  insert_instant      BIGINT       NOT NULL,
  is_default          BIT(1)       NOT NULL,
  is_super_role       BIT(1)       NOT NULL,
  last_update_instant BIGINT       NOT NULL,
  name                VARCHAR(191) NOT NULL,
  PRIMARY KEY (id),
  CONSTRAINT application_roles_uk_1 UNIQUE (name, applications_id),
  CONSTRAINT application_roles_fk_1 FOREIGN KEY (applications_id) REFERENCES app
lications(id)
  ENGINE = innodb
CREATE TABLE `groups` (
  data                MEDIUMTEXT   NULL,
  tenants_id          BINARY(16)   NOT NULL,
  PRIMARY KEY (id),
  CONSTRAINT groups_uk_1 UNIQUE (name, tenants_id),
  CONSTRAINT groups_fk_1 FOREIGN KEY (tenants_id) REFERENCES tenants(id)
  ENGINE = innodb
CREATE TABLE group_application_roles (
  application_roles_id BINARY(16) NOT NULL,
  groups_id            BINARY(16) NOT NULL,
  CONSTRAINT group_application_roles_uk_1 UNIQUE (groups_id, application_roles_i
d),
  CONSTRAINT group_application_roles_fk_1 FOREIGN KEY (groups_id) REFERENCES `gr
oups`(id),
  CONSTRAINT group_application_roles_fk_2 FOREIGN KEY (application_roles_id) REF
ERENCES application_roles(id)
  ENGINE = innodb
CREATE TABLE webhooks (
  connect_timeout              INTEGER      NOT NULL,
  data                         TEXT         NULL,
  global                       BIT(1)       NOT NULL,
  headers                      TEXT         NULL,
  http_authentication_username VARCHAR(255) NULL,
  http_authentication_password VARCHAR(255) NULL,
  read_timeout                 INTEGER      NOT NULL,
  ssl_certificate              TEXT         NULL,
  url                          TEXT         NOT NULL,
  PRIMARY KEY (id)
  ENGINE = innodb
CREATE TABLE webhooks_applications (
  webhooks_id     BINARY(16) NOT NULL,
  PRIMARY KEY (webhooks_id, applications_id),
  CONSTRAINT webhooks_applications_fk_1 FOREIGN KEY (webhooks_id) REFERENCES web
hooks(id),
  CONSTRAINT webhooks_applications_fk_2 FOREIGN KEY (applications_id) REFERENCES
 applications(id)
  ENGINE = innodb
-- External Ids
CREATE TABLE external_identifiers (
  id              VARCHAR(191) NOT NULL,
  applications_id BINARY(16)   NULL,
  data            TEXT         NULL,
  type            SMALLINT     NOT NULL,
  users_id        BINARY(16)   NULL,
  PRIMARY KEY (id),
  CONSTRAINT external_identifiers_fk_1 FOREIGN KEY (users_id) REFERENCES users(i
d),
  CONSTRAINT external_identifiers_fk_2 FOREIGN KEY (applications_id) REFERENCES
applications(id),
  CONSTRAINT external_identifiers_fk_3 FOREIGN KEY (tenants_id) REFERENCES tenan
ts(id)
  ENGINE = innodb
CREATE INDEX external_identifiers_i_1 ON external_identifiers(tenants_id, type,
insert_instant);
CREATE INDEX external_identifiers_i_2 ON external_identifiers(type, users_id, ap
plications_id);
CREATE TABLE user_registrations (
  authentication_token VARCHAR(255) NULL,
  clean_speak_id       BINARY(16)   NULL,
  last_login_instant   BIGINT       NULL,
  timezone             VARCHAR(255) NULL,
  username             VARCHAR(191) NULL,
  username_status      SMALLINT     NOT NULL,
  users_id             BINARY(16)   NOT NULL,
  verified             BIT(1)       NOT NULL,
  PRIMARY KEY (id),
  CONSTRAINT user_registrations_uk_1 UNIQUE KEY (applications_id, users_id),
  CONSTRAINT user_registrations_fk_1 FOREIGN KEY (applications_id) REFERENCES ap
plications(id),
  CONSTRAINT user_registrations_fk_2 FOREIGN KEY (users_id) REFERENCES users(id)
  ENGINE = innodb
CREATE INDEX user_registrations_i_1 ON user_registrations(clean_speak_id);
# No need to create an explicit index on applications_id because it is the first
 key in the UNIQUE constraint
CREATE INDEX user_registrations_i_2 ON user_registrations(users_id);
CREATE TABLE user_registrations_application_roles (
  user_registrations_id BINARY(16) NOT NULL,
  CONSTRAINT user_registrations_application_roles_uk_1 UNIQUE (user_registration
s_id, application_roles_id),
  CONSTRAINT user_registrations_application_roles_fk_1 FOREIGN KEY (user_registr
ations_id) REFERENCES user_registrations(id),
  CONSTRAINT user_registrations_application_roles_fk_2 FOREIGN KEY (application_
roles_id) REFERENCES application_roles(id)
  ENGINE = innodb
CREATE TABLE families (
  family_id           BINARY(16) NOT NULL,
  owner               BIT(1)     NOT NULL,
  role                SMALLINT   NOT NULL,
  PRIMARY KEY (family_id, users_id),
  CONSTRAINT families_fk_1 FOREIGN KEY (users_id) REFERENCES users(id)
  ENGINE = innodb
CREATE INDEX families_i_1 ON families(users_id);
CREATE TABLE group_members (
  PRIMARY KEY (id),
  CONSTRAINT group_members_uk_1 UNIQUE (groups_id, users_id),
  CONSTRAINT group_members_fk_1 FOREIGN KEY (users_id) REFERENCES users(id),
  CONSTRAINT group_members_fk_2 FOREIGN KEY (groups_id) REFERENCES `groups`(id)
  ENGINE = innodb
CREATE INDEX group_members_i_1 ON group_members(users_id);
# No need to create an explicit index on groups_id because it is the first key i
CREATE TABLE user_action_logs (
  actioner_users_id  BINARY(16)   NULL,
  actionee_users_id  BINARY(16)   NOT NULL,
  comment            TEXT         NULL,
  email_user_on_end  BIT(1)       NOT NULL,
  end_event_sent     BIT(1)       NULL,
  expiry             BIGINT       NULL,
  history            TEXT         NULL,
  localized_name     VARCHAR(191) NULL,
  localized_option   VARCHAR(255) NULL,
  localized_reason   VARCHAR(255) NULL,
  notify_user_on_end BIT(1)       NOT NULL,
  option_name        VARCHAR(255) NULL,
  reason_code        VARCHAR(255) NULL,
  user_actions_id    BINARY(16)   NOT NULL,
  PRIMARY KEY (id),
  CONSTRAINT user_action_logs_fk_1 FOREIGN KEY (actioner_users_id) REFERENCES us
ers(id),
  CONSTRAINT user_action_logs_fk_2 FOREIGN KEY (actionee_users_id) REFERENCES us
ers(id),
  CONSTRAINT user_action_logs_fk_3 FOREIGN KEY (user_actions_id) REFERENCES user
_actions(id)
  ENGINE = innodb
CREATE INDEX user_action_logs_i_1 ON user_action_logs(insert_instant);
CREATE INDEX user_action_logs_i_2 ON user_action_logs(expiry, end_event_sent);
CREATE TABLE user_action_logs_applications (
  user_action_logs_id BINARY(16) NOT NULL,
  CONSTRAINT user_action_logs_applications_fk_1 FOREIGN KEY (applications_id) RE
FERENCES applications(id)
    ON DELETE CASCADE,
  CONSTRAINT user_action_logs_applications_fk_2 FOREIGN KEY (user_action_logs_id
) REFERENCES user_action_logs(id)
    ON DELETE CASCADE
  ENGINE = innodb
CREATE TABLE user_comments (
  comment        TEXT       NULL,
  commenter_id   BINARY(16) NOT NULL,
  PRIMARY KEY (id),
  CONSTRAINT user_comments_fk_1 FOREIGN KEY (users_id) REFERENCES users(id),
  CONSTRAINT user_comments_fk_2 FOREIGN KEY (commenter_id) REFERENCES users(id)
  ENGINE = innodb
CREATE INDEX user_comments_i_1 ON user_comments(insert_instant);
CREATE INDEX user_comments_i_2 ON user_comments(users_id);
CREATE INDEX user_comments_i_3 ON user_comments(commenter_id);
CREATE TABLE authentication_keys (
  permissions         TEXT         NULL,
  meta_data           TEXT         NULL,
  tenants_id          BINARY(16)   NULL,
  PRIMARY KEY (id),
  CONSTRAINT authentication_keys_fk_1 FOREIGN KEY (tenants_id) REFERENCES tenant
s(id)
  ENGINE = innodb
CREATE TABLE system_configuration (
  data                LONGTEXT     NOT NULL,
  report_timezone     VARCHAR(255) NOT NULL
  ENGINE = innodb
CREATE TABLE raw_logins (
  ip_address      VARCHAR(255) NULL,
  CONSTRAINT raw_logins_fk_1 FOREIGN KEY (applications_id) REFERENCES applicatio
ns(id),
  CONSTRAINT raw_logins_fk_2 FOREIGN KEY (users_id) REFERENCES users(id)
  ENGINE = innodb
CREATE INDEX raw_logins_i_1 ON raw_logins(instant);
CREATE INDEX raw_logins_i_2 ON raw_logins(users_id, instant);
CREATE TABLE hourly_logins (
  at org.mybatis.guice.MyBatisModule.bindDataSourceProviderType(MyBatisModule.ja
va:289) (via modules: io.fusionauth.app.guice.FusionAuthModule -> com.google.inj
ect.util.Modules$OverrideModule -> io.fusionauth.api.guice.APIModule -> io.fusio
nauth.api.domain.guice.MyBatisModule)
  while locating javax.sql.DataSource
    for field at org.mybatis.guice.environment.EnvironmentProvider.dataSource(En
vironmentProvider.java:52)
  at org.mybatis.guice.environment.EnvironmentProvider.class(EnvironmentProvider
.java:27)
  while locating org.mybatis.guice.environment.EnvironmentProvider
  at org.mybatis.guice.MyBatisModule.internalConfigure(MyBatisModule.java:110) (
via modules: io.fusionauth.app.guice.FusionAuthModule -> io.fusionauth.api.migra
tion.guice.MigrationModule)
  while locating org.apache.ibatis.mapping.Environment
    for the 1st parameter of org.mybatis.guice.configuration.ConfigurationProvid
er.<init>(ConfigurationProvider.java:109)
  at org.mybatis.guice.configuration.ConfigurationProvider.class(ConfigurationPr
ovider.java:39)
  while locating org.mybatis.guice.configuration.ConfigurationProvider
  at org.mybatis.guice.MyBatisModule.internalConfigure(MyBatisModule.java:113) (
  while locating org.apache.ibatis.session.Configuration
    for the 1st parameter of org.mybatis.guice.session.SqlSessionFactoryProvider
.createNewSqlSessionFactory(SqlSessionFactoryProvider.java:59)
  at org.mybatis.guice.session.SqlSessionFactoryProvider.class(SqlSessionFactory
Provider.java:26)
  while locating org.mybatis.guice.session.SqlSessionFactoryProvider
  while locating org.apache.ibatis.session.SqlSessionFactory
    for the 1st parameter of org.mybatis.guice.session.SqlSessionManagerProvider
.createNewSqlSessionManager(SqlSessionManagerProvider.java:49)
  at org.mybatis.guice.session.SqlSessionManagerProvider.class(SqlSessionManager
Provider.java:24)
  while locating org.mybatis.guice.session.SqlSessionManagerProvider
  at org.mybatis.guice.AbstractMyBatisModule.configure(AbstractMyBatisModule.jav
a:59) (via modules: io.fusionauth.app.guice.FusionAuthModule -> io.fusionauth.ap
i.migration.guice.MigrationModule)
  while locating org.apache.ibatis.session.SqlSessionManager
    for field at org.mybatis.guice.mappers.MapperProvider.sqlSessionManager(Mapp
erProvider.java:37)
  while locating org.mybatis.guice.mappers.MapperProvider
  at com.google.inject.util.Providers$GuicifiedProviderWithDependencies.initiali
ze(Providers.java:154)
  at org.mybatis.guice.AbstractMyBatisModule.bindMapper(AbstractMyBatisModule.ja
va:96) (via modules: io.fusionauth.app.guice.FusionAuthModule -> io.fusionauth.a
pi.migration.guice.MigrationModule)
38) null returned by binding at org.mybatis.guice.MyBatisModule.bindDataSourcePr
oviderType(MyBatisModule.java:289) (via modules: io.fusionauth.app.guice.FusionA
uthModule -> com.google.inject.util.Modules$OverrideModule -> io.fusionauth.api.
guice.APIModule -> io.fusionauth.api.domain.guice.MyBatisModule)
 but org.mybatis.guice.environment.EnvironmentProvider.dataSource(EnvironmentPro
vider.java:52) is not @Nullable
  while locating com.inversoft.jdbc.hikari.DataSourceProvider
.java:27)
ovider.java:39)
Provider.java:26)
Provider.java:24)
    for field at org.mybatis.guice.transactional.TransactionalMethodInterceptor.
sqlSessionManager(TransactionalMethodInterceptor.java:56)
  at org.mybatis.guice.AbstractMyBatisModule.bindTransactionInterceptors(Abstrac
tMyBatisModule.java:79) (via modules: io.fusionauth.app.guice.FusionAuthModule -
> com.google.inject.util.Modules$OverrideModule -> io.fusionauth.api.guice.APIMo
39) null returned by binding at org.mybatis.guice.MyBatisModule.bindDataSourcePr
.java:27)
ovider.java:39)
Provider.java:26)
Provider.java:24)
> com.google.inject.util.Modules$OverrideModule -> io.fusionauth.app.guice.Fusio
nAuthAPIAuthenticationModule)
40) null returned by binding at org.mybatis.guice.MyBatisModule.bindDataSourcePr
.java:27)
ovider.java:39)
Provider.java:26)
Provider.java:24)
> com.google.inject.util.Modules$OverrideModule -> com.inversoft.authentication.
api.guice.APIAuthenticationModule)
41) null returned by binding at org.mybatis.guice.MyBatisModule.bindDataSourcePr
.java:27)
