    2. sameer.syedmanzur
    S
    • Topics 1
    • Posts 1
    • Best 0
    Posts made by sameer.syedmanzur
    • Automating 2FA Login via API without SMTP: How to retrieve or inject OTP?
      I'm working on automating a 2FA login flow for testing/scripting purposes using the FusionAuth API. My environment currently does not have SMTP configured, so I cannot rely on standard email delivery for the OTP.
      I want to handle the 2FA authentication step purely via API using my FusionAuth API Key. Could anyone guide me on the best approach to achieve this?
      Specifically, I have a few ideas based on the documentation but would love some community validation:
      Provide a custom code: I noticed that the /api/two-factor/start endpoint allows you to pass a custom code in the request body. Is this the recommended way to bypass external delivery mechanisms during automation?
      Use TOTP (Authenticator): Should I instead enable TOTP for the test user, grab the secretBase32Encoded via the /api/two-factor/secret endpoint, and programmatically generate the 6-digit code inside my test script using a TOTP library?
      If anyone has a quick cURL example or best practice recommendations for handling this flow purely via API, I'd really appreciate it!
      Thanks in advance!
      posted in Q&A
      S
      sameer.syedmanzur
