    2. shaheem.aziz
    S
    • Topics 1
    • Posts 1
    • Best 0
    Posts made by shaheem.aziz
    • Can role name be changed using PATCH api
      Hi guys,
      My name is Shaheem and I am new to the forum. I am trying to learn and integrate FusionAuth as the identity provider for my framework and so far it has been a excellent experience. Thumbs up guys 👍 . Its definitely one of easiest Identity provider I have worked with and the API and documentation is excellent 👍
      Anyways I have been having some issues with the PATCH command for roles "/api/application/{applicationId}/role/{roleId}". I am trying to update the role name and it simply does not update.
      FusionAuth Version: 1.30.2
      MultiTenancy Setup: Yes
      API Key: Global Key - No Tenants selected
      I am using .Net 5 (Web Api with Blazor wasm standalone) with direct FusionAuth REST API but I was able to replicate the issue with postman as well as shown below.
      1 - Test to change the name of an existing role
      • Existing name of the Role was "New Role"
      • Tried to change the role name to "Test Role Updated"
      2 - Test to update the role name and and other properties (IsDefault & description)
      • Existing isDefault value was "false" (as in previous screenshot)
      • There was no existing description
      Question: Can role names be updated via api?
      Anyways it would be great if you could have a look at the issue
      Thanks
      Shaheem
      posted in Q&A
      S
      shaheem.aziz
