After futher investigation, I asked the client to
- include the x509 certificate in their reponse
- sign the assertion
This fixed the issue. But still, it would be nice for Fusionauth to handle this a little more gracefully.
I have managed to successfully set up SAMLv2 with Azure AD, however one of my clients is using Ping Federate and the integration is throwing a 500 error when reading the SAML response:
Unable to parse or validate SAML response.
Exception:
java.lang.NullPointerException
at io.fusionauth.api.security.SAMLKeySelector.select(SAMLKeySelector.java:35)
at java.xml.crypto/org.jcp.xml.dsig.internal.dom.DOMXMLSignature$DOMSignatureValue.validate(DOMXMLSignature.java:556)
at java.xml.crypto/org.jcp.xml.dsig.internal.dom.DOMXMLSignature.validate(DOMXMLSignature.java:268)
at io.fusionauth.samlv2.service.DefaultSAMLv2Service.verifyEmbeddedSignature(DefaultSAMLv2Service.java:957)
at io.fusionauth.samlv2.service.DefaultSAMLv2Service.parseResponse(DefaultSAMLv2Service.java:592)
at io.fusionauth.api.service.authentication.SAMLv2IdentityProviderAuthenticationService._login(SAMLv2IdentityProviderAuthenticationService.java:91)
at io.fusionauth.api.service.authentication.SAMLv2IdentityProviderAuthenticationService$$EnhancerByGuice$$2d68788c.CGLIB$_login$4(<generated>)
at io.fusionauth.api.service.authentication.SAMLv2IdentityProviderAuthenticationService$$EnhancerByGuice$$2d68788c$$FastClassByGuice$$20fb48ec.invoke(<generated>)
at com.google.inject.internal.cglib.proxy.$MethodProxy.invokeSuper(MethodProxy.java:228)
at com.google.inject.internal.InterceptorStackCallback$InterceptedMethodInvocation.proceed(InterceptorStackCallback.java:76)
at org.mybatis.guice.transactional.TransactionalMethodInterceptor.invoke(TransactionalMethodInterceptor.java:96)
at com.google.inject.internal.InterceptorStackCallback$InterceptedMethodInvocation.proceed(InterceptorStackCallback.java:78)
at com.google.inject.internal.InterceptorStackCallback.intercept(InterceptorStackCallback.java:54)
at io.fusionauth.api.service.authentication.SAMLv2IdentityProviderAuthenticationService$$EnhancerByGuice$$2d68788c._login(<generated>)
at io.fusionauth.api.service.authentication.BaseIdentityProviderAuthenticationService.login(BaseIdentityProviderAuthenticationService.java:97)
at io.fusionauth.app.action.api.identityProvider.LoginAction.lambda$post$0(LoginAction.java:63)
at io.fusionauth.app.action.api.BaseLoginAction.callLogin(BaseLoginAction.java:166)
at io.fusionauth.app.action.api.identityProvider.LoginAction.post(LoginAction.java:63)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.primeframework.mvc.util.ReflectionUtils.invoke(ReflectionUtils.java:414)
at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.execute(DefaultActionInvocationWorkflow.java:79)
at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.perform(DefaultActionInvocationWorkflow.java:62)
at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:51)
at org.primeframework.mvc.validation.DefaultValidationWorkflow.perform(DefaultValidationWorkflow.java:47)
at org.primeframework.mvc.security.DefaultSecurityWorkflow.perform(DefaultSecurityWorkflow.java:60)
at org.primeframework.mvc.parameter.DefaultPostParameterWorkflow.perform(DefaultPostParameterWorkflow.java:50)
at org.primeframework.mvc.content.DefaultContentWorkflow.perform(DefaultContentWorkflow.java:52)
at org.primeframework.mvc.parameter.DefaultParameterWorkflow.perform(DefaultParameterWorkflow.java:57)
at org.primeframework.mvc.parameter.DefaultURIParameterWorkflow.perform(DefaultURIParameterWorkflow.java:102)
at org.primeframework.mvc.scope.DefaultScopeRetrievalWorkflow.perform(DefaultScopeRetrievalWorkflow.java:58)
at org.primeframework.mvc.message.DefaultMessageWorkflow.perform(DefaultMessageWorkflow.java:44)
at io.fusionauth.app.primeframework.FrontEndTenantWorkflow.perform(FrontEndTenantWorkflow.java:79)
at org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:126)
at org.primeframework.mvc.workflow.StaticResourceWorkflow.perform(StaticResourceWorkflow.java:97)
at org.primeframework.mvc.parameter.RequestBodyWorkflow.perform(RequestBodyWorkflow.java:91)
at org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:64)
at io.fusionauth.app.primeframework.CORSFilter.doFilter(CORSFilter.java:262)
at io.fusionauth.app.primeframework.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:49)
at io.fusionauth.app.primeframework.FusionAuthMVCWorkflow.perform(FusionAuthMVCWorkflow.java:88)
at org.primeframework.mvc.workflow.DefaultWorkflowChain.continueWorkflow(DefaultWorkflowChain.java:44)
at org.primeframework.mvc.servlet.FilterWorkflowChain.continueWorkflow(FilterWorkflowChain.java:50)
at org.primeframework.mvc.servlet.PrimeFilter.doFilter(PrimeFilter.java:78)
at com.inversoft.maintenance.servlet.MaintenanceModePrimeFilter.doFilter(MaintenanceModePrimeFilter.java:63)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at com.inversoft.servlet.UTF8Filter.doFilter(UTF8Filter.java:27)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:353)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:616)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1629)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:832)
I'm running v1.26.1
Any way to customise the body of a webhook? I'd like to pump some events in to Slack but Slack doesn't allow you to do any transform on their end, all inbound webhooks must meet their spec.
I'm trying to work out if there is a way to email users automatically when they trigger the failed authentication user action.
E.g. once they put the incorrect password in 5 times, the tenant failed authentication settings trigger a User action called "Lock out". However this doesn't seem to send out the email that is specified in userAction.startEmailTemplateId.
