    2. Troy Squillaci
    T
    • Topics 1
    • Posts 1
    • Best 1
    Posts made by Troy Squillaci
    • Helm Chart not picking up on database credentials in production mode
      I am deploying FusionAuth in Kubernetes using the latest Helm chart version (0.12.1), with PostgreSQL as the database and FUSIONAUTH_APP_RUNTIME_MODE set to production. I have created a non-root user and database and am trying to get FusionAuth to take the credentials to perform the initial installation.
      Here's some excerpts from the values.yaml:
        database:
          # database.protocol -- Should either be postgresql or mysql. Protocol for jdbc connection to database
          protocol: postgresql
          # database.host -- Hostname or ip of the database instance
          host: "<REDACTED>"
          # database.host -- Port of the database instance
          port: 5432
          # database.tls -- Configures whether or not to use tls when connecting to the database
          tls: false
          # database.tlsMode -- If tls is enabled, this configures the mode
          tlsMode: require
          # database.name -- Name of the fusionauth database
          # To use an existing secret, set `existingSecret` to the name of the secret. We expect at most two keys: `password` is required. `rootpassword` is only required if `database.root.user` is set.
          # database.existingSecret -- The name of an existing secret that contains the database passwords
          existingSecret: "fusionauth"
          # database.user -- Database username for fusionauth to use in normal operation
          user: "fusionauth"
          # database.password -- Database password for fusionauth to use in normal operation - not required if database.existingSecret is configured
          password: ""
          # These credentials are used for bootstrapping the database
          root:
            # database.root.user -- Database username for fusionauth to use during initial bootstrap - not required if you have manually bootstrapped your database
            user: ""
            # database.root.password -- Database password for fusionauth to use during initial bootstrap - not required if database.existingSecret is configured
            password: ""
        app:
          # app.memory -- Configures the amount of memory Java can use
          memory: 256M
          # app.memory -- Configures runtime mode for fusionauth. Should be 'development' or 'production'
          # learn more about the difference here: https://fusionauth.io/docs/v1/tech/reference/configuration
          runtimeMode: production
      I can confirm with psql that I'm able to connect and operate in the database just fine. I've also confirmed the secret is applied to the cluster prior to deploying the Helm chart.
      The FUSIONAUTH_APP_SILENT_MODE defaults to true, so I would expect FusionAuth to take the credentials and database configuration listed here and do the rest automatically, but it doesn't seem to be the case, as I get the following logs:
      Defaulted container "fusionauth" out of: fusionauth, wait-for-db (init)
      Starting fusionauth-app...
        --> Logging to /usr/local/fusionauth/logs/fusionauth-app.log
      2023-05-23 01:38:23.656 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/usr/local/fusionauth/config/fusionauth.properties]
      2023-05-23 01:38:23.820 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Set property [fusionauth-app.url] set to [<REDACTED>] using configured value.
      2023-05-23 01:38:23.830 PM INFO  com.inversoft.configuration.BasePropertiesFileInversoftConfiguration -
        - Overriding default value of property [FUSIONAUTH_APP_RUNTIME_MODE] with value [production]
        - Overriding default value of property [SEARCH_TYPE] with value [database]
      2023-05-23 01:38:23.851 PM INFO  io.fusionauth.app.guice.FusionAuthModule -
      --------------------------------- Starting FusionAuth version [1.45.1] ----------------------------------
      2023-05-23 01:38:24.260 PM INFO  io.fusionauth.api.plugin.guice.PluginModule - No plugins found
      2023-05-23 01:38:24.543 PM INFO  io.fusionauth.api.service.system.NodeService - Node [39f625d7-1c08-4239-a849-5b0f958a2263] started.
      2023-05-23 01:38:25.398 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/usr/local/fusionauth/config/fusionauth.properties]
      2023-05-23 01:38:25.399 PM INFO  com.inversoft.configuration.BasePropertiesFileInversoftConfiguration -
      2023-05-23 01:38:25.404 PM INFO  com.inversoft.jdbc.hikari.DataSourceProvider - Connecting to PostgreSQL database at [jdbc:postgresql://<REDACTED>:5432/fusionauth]
      2023-05-23 01:38:25.405 PM WARN  com.zaxxer.hikari.HikariConfig - HikariPool-1 - idleTimeout has been set but has no effect because the pool is operating as a fixed size pool.
      2023-05-23 01:38:25.407 PM INFO  com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Starting...
      2023-05-23 01:38:26.168 PM INFO  com.zaxxer.hikari.pool.HikariPool - HikariPool-1 - Added connection org.postgresql.jdbc.PgConnection@4c6a4ffd
      2023-05-23 01:38:26.211 PM INFO  com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Start completed.
      2023-05-23 01:38:28.369 PM INFO  com.inversoft.scheduler.DefaultScheduler - Starting up scheduler
      2023-05-23 01:38:28.369 PM INFO  com.inversoft.scheduler.DefaultScheduler - Scheduler is running
      2023-05-23 01:38:28.456 PM ERROR com.inversoft.scheduler.LogAndRetainFailureHandler - The scheduled service [class io.fusionauth.api.service.cache.ApplicationCacheLoader] failed but will be re-run.
      ### Error querying database.  Cause: org.postgresql.util.PSQLException: ERROR: relation "applications" does not exist
        Position: 4355
      Any ideas on why it's not picking up on the database details and/or why it's failing to perform the initial installation?
      posted in General Discussion
      T
      Troy Squillaci
