    How to search for username with hyphen
    6.1k
    • M
      malle
      Hello,
      assume having two users
      test-good
      test-better
      Seemingly the hyphen ist like a special char and won't work with asterisk for like-search.
      You can try this in the web UI:
      Search for username:test -> Users will be found
      Search for username:test* -> Users will be found
      Search for username:test-* -> No search result
      Quoting the hyphen with backslash has no effect. Is there a way to achieve this?
      Thank you and regards
        Hmmm.
        Which search engine are you using, elasticsearch or the database search engine?
        What version of FusionAuth are you using?
        • M
          malle
          Hey @dan
          this seemingly occurs with V1.23.3 and also with V1.17.4.
          And with both search engines, database and elasticsearch.
            A Former User
            @malle said in How to search for username with hyphen:
            Does this work?
            Search for username:"test-*"
              Hi @malle ,
              Took some time to dig into this a bit more.
              I have a system which has a user with a username test2-name.
              If I use the database search for this user, all of these return the user:
              • test2
              • test2*
              • test2-
              • test2-*
              • test2-n
              • test2-n*
              Note that you don't put the username: prefix on any database searches.
              If on the other hand I use the elasticsearch search engine, and search for the same user, I see the following:
              • username:test2 -> found
              • username:test2* -> found
              • username:test2- -> found
              • username:test2-* -> not found
              • username:test2-n -> found
              • username:test2-n* -> not found
              I'm not quite sure what's going on with the wildcard causing Elastic to not find the value, but don't think it is related to the -.
                A Former User
                @dan
                Did you try quoting the value?
                • username:"test2-*"
                • username:"test2-n*"
                  Running with quotes works in one case:
                  • username:"test2-*" -> found
                  • username:"test2-n*" -> not found
                  • M
                    malle @dan
                    @dan
                    username:"test2-n*" -> not found ...so still a problem.
                    And I do not really care about the FusionAuth Web UI, the problem actually is that I use the Java client via UserSearchCriteria ...so it is quoted anyways. Unfortunetally there are already a lot of 'hyphen-user' in the system and adjusting these by taking the hyphen out is not an option.
                      A Former User
                      I think the problem is that we are indexing username with the default text analyzer which uses a hyphen (-) as a separating character.
                      This means Elasticsearch has indexed test-good and found two tokens test and good.
                      Without changing the way this field is indexed, I think you can achieve your desired results by modifying your query.
                      For example, to search for test-g*, you would break this into two parts, and structure your search like this: username:"test" AND username:g*. This will find all usernames that include the token test and a have a second token token that begins with g.
                      Try this strategy and see if it works for you.
                      • M
                        malle @A Former User
                        In the meantime we could implemented it with the mentioned workaround.
                        Late thanks @robotdan !
