OR, perhaps a new concept is needed in FusionAuth -- "Organizations" if you will -- that allows for granting users with different permission sets inside the same Application.
You should feel free to open up a feature request here.
@05-years_tourer have you tried to clear you cache and try again?
@mr-sahand Have you considered using a lambda to populate the info as you want it?
SAML v2 Populate Lambda (https://fusionauth.io/docs/extend/code/lambdas/samlv2-response-populate)
@marco-0 Couldn't you add some logic to the redirect page and send the user to the correct one based on the situation?
@vandaele-seba A tenant in FusionAuth is a named object that represents a discrete namespace for Users, Applications, and Groups. It is a way to separate Users, Applications, and Registrations into separate containers. There is a diagram in the documentation that may help.
@andy-2 are you talking about self-hosted or Fusion-Auth hosted?
@david-5 Which version of Visual Studio are you using?
@admin-9 I have not worked with Metabase, so I don't think I can be of help there. I do want to make sure you have seen the documentation on configuring FusionAuth as the Service Provider.
It is worth noting the bit about opening up a request for FusionAuth to provide additional examples on Github. It may be worth you time to do that.
@essamkayall1996 Are you able to debug and confirm "client' is in the list of user.roles? Also are you saying that no page renders? What error message are you getting? It looks like in either case of if statement that you are returning the same page.
@fin When you say the cookies are blocked, what error message are you getting? What do you mean by blocked?
@fc I responded to your issue post on Github. I would like to help.
@jacob-0 Sorry to hear you are having issues. Thank you for the detailed post explaining it. Unfortunately, random unavailability can be very difficult to troubleshoot.
Based on your explanation, it seems as though the instance is available from outside the GKE cluster. Could this be an issue with one of the pods going down and being restarted and the internal networking not recognizing the change? I don't quite see how it would still work from the outside, but is there any evidence of pods restarting around the down time?
@yuriy-barvenko Performance tweaking can be tricky. It really depends on what your goals are. If you create indexes to improve searching things, it could slow other things down like the login. It may also depend on which database you are using. What DB are you using? What is the purpose of the information you are trying to get? Does it have to be real time? Are there alternatives like data dumps that you could use? Also, you say "the response times are significantly higher than expected." What is this based on? How many users and roles do you have in the system and what is the expected response time? What is the requirement for response time vs what is expected?
@bill-yudichak Can you please get us a little more detail. A screenshot may help. I do not see a "Go Back" link when I enable multi-factor for my app. Also, what is the accountTwoFactorIndex template you are referring to?
@helzgate I was focusing on your issue with the lambda not firing. You are correct in that you do not have access to the url in the lambda.
Let's take a step back here and take a look at the connector. Can you tell me how that is set up and what values are being returned from it? I'm thinking you may be able to add the return_url in the values returned from that.
@helzgate Just to verify, is this a JWT Reconcile lambda (you may need to try External JWT Reconcile as well depending on what you are doing)? And you have it assigned to your applicaiton?
Beyond that, I think I need a little more detail on exactly how you have things set up. What are you trying to migrate from? That sort of thing.
@marshsouvlakia What version of mysql are you running? Were there any updates recently? Anything that may have changes from when it was not working to now? Have you tried a restart?
@yves So I found this that may be of interest to you.
For the Authorization Code Grant, if the clientAuthenticationPolicy value is Required, the client secret is required. If the value is NotRequired, the client secret is not required. If the value is NotRequiredWhenUsingPKCE and PKCE is used, the client secret is not required. If PKCE is not used, the client secret is required.
What is your setting there?
@helzgate What kind of lambda are you using? You should enable debugging for the lambda and then you can be sure to see if it is running or not.
