    Data loss and FusionAuth Cloud Basic plan
    fusionauth cloud basic data loss
    5.0k
      The basic cloud plan says that total data loss can occur if the server crashes. Can you explain? It can't be just a simple server crash. You have persistent storage yes?
        In FusionAuth Basic Cloud, the database is installed on the same host using a persistent volume.
        While data loss would be rare, we clearly state the possibility because this deployment model is not intended for production.
        The Business and High Availability editions offer a managed database which includes additional redundancies, automated backups and higher performance characteristics that make it much better suited for production usage.
        In the event of a catastrophic failure or natural disaster, we do not guarantee any service level or recovery point for the Basic Cloud edition.
        • G
          garveymozga33
          Data recovery will not be a problem if you regularly make manual backups or configure automatic backups. You can simply backup the system to its state before the critical error.
            dan @garveymozga33
            @garveymozga33 Thanks for your feedback. The basic cloud plan does not currently include backups and is not intended for production use.
