Hello i hope you are doing great. A few weeks ago i started an implementation of social Login for Microsoft accounts (Azure AD).
Obviously i read the fusionauth documentation as a base to know how to implement this feature and because i am using the ReactJs Application, the packaged i am using is https://fusionauth.io/docs/v1/tech/client-libraries/node
As the documentation says the way to implement this is with OpenIdConnect, so i started using this identity provider and the configuration was added. At the beggining this was configured using the OAuth 2.0 v2 endpoints.. But i had an issue with PKCE, apparently there is no way to pass the challenge code to the fusionauthClient.identityProviderLogin method to complete the identity provider login flow.
So i just changed the configuration to OAuth 2.0 v1 endpoints, and from there the identity provider login works fine with Microsoft Accounts.. But when i try with Microsoft enterprise accounts the identity provider login fails .
So, with this context i have two questions:
- Is this issue related with the Oauth 2.0 version selected
- If yes.. Is there a way to pass this challenge code to the fusionAuthClient to complete this the identity provider flow. If not possible with the fusionauthClient, Is there a way to do it with the fusion auth api endpoints?
I think this is it. I really appreciate your help with this. Thanks
Hiya, can you enable debug on the Identity Provider connection and then share your event log? That might shed some light on things.
Also, the node client library is deprecated and we recommend using the typescript library.
D dan referenced this topic on
@dan Thanks for answer to this post. I will proceed to check this tomorrow and i will let you know how this goes after testing it again. I didn't know that the node client was deprecated.. so thanks for the update about this.. i am going to replace the package for the typescript library
@dan Good evening, I hope you are doing great. I just proceed to enable the debug for identity provider (That was enabled already).
I am using v1 ad endpoints, i reproduce the error, but fusionauth doesn't show any errors, because i think that this don't have nothing to do with fusionauth. The error that azure shows is:
AADSTS50020: User account 'email@example.com' from identity provider 'https://sts.windows.net/<tenant-id>/' does not exist in tenant 'Directorio predeterminado' and cannot access the application '<app-id>'(<app name>) in that tenant. The account needs to be added as an external user in the tenant first. Sign out and sign in again with a different Azure Active Directory user account.The fact that fusionauth dont detect any error is kind of expected because at this point we are on azure login flow. I am assuming that this is related to the
v1 endpointson azure AD.The first time i just started using the
v2 endpointsbut the problem was fusionauth, and the error was the challenge because the javascript library method dont have any param to pass the challenge values. So my question here isIs the Typescript client supporting PKCE authentication challenge. If the answer is negative. ThenIt is possible to achieve this with the fusionauth endpoints(passing the challenge codes to the endpoint to complete the flow) -
Now using v2 endpoints (passing the code_challenge and the code_challenge_method to retrieve the authorization token https://docs.microsoft.com/en-us/azure/active-directory/develop/v2-oauth2-auth-code-flow). Fusionauth Microsoft OpenIDConnect provider returns the next error:
Request to the [https://login.microsoftonline.com/<tenant-id>/oauth2/token] endpoint failed. Status code [400]. Error response is { "error" : "invalid_grant", "error_description" : "AADSTS50148: The code_verifier does not match the code_challenge supplied in the authorization request for PKCE.\r\nTrace ID: c0836075-1551-45ad-9fce-9b7a7716d201\r\nCorrelation ID: 16f33aed-50eb-461a-9740-66299e56fe58\r\nTimestamp: 2022-05-12 15:57:26Z", "error_codes" : [ 50148 ], "timestamp" : "2022-05-12 15:57:26Z", "trace_id" : "c0836075-1551-45ad-9fce-9b7a7716d201", "correlation_id" : "16f33aed-50eb-461a-9740-66299e56fe58", "error_uri" : "https://login.microsoftonline.com/error?code=50148" }I assume that this is because there is no way to pass this challenge code. Also i Notice that the url used by
fusionauthto get the token is av1endpointhttps://login.microsoftonline.com/<tenant-id>/oauth2/token. So i ask again, is there a way to usev2endpoints andcode_challengeto complete the login flow for Microsoft OpenIdConnect providers? -
So I want to sum up what you are doing to make sure I understand.
- You are trying to add a 'login with microsoft' button.
- You are using the OIDC Identity provider.
- You are not using the FusionAuth hosted login pages (you want to control the UX yourself) and are using the 'complete' API call documented here: https://fusionauth.io/docs/v1/tech/apis/identity-providers/openid-connect#complete-an-openid-connect-login
- You are trying to use v2 for the endpoints.
- You are using the typescript client.
Is that correct? Because if you are using the hosted login pages (more here about that) then you should be able to follow these instructions: https://fusionauth.io/docs/v1/tech/identity-providers/openid-connect/azure-ad
We have an example react application where you redirect over to the FusionAuth hosted login pages (which you can theme) and then get sent back to react. Here's a blog post about this: https://fusionauth.io/blog/2021/11/11/how-to-authenticate-your-react-app
While I understand this topic has been previously discussed, I believe it's still relevant due to the similarity in my use case.
I'm currently integrating Discord login into my application using the OpenID Connect identity provider. My goal is to implement a custom user experience that doesn't rely on FusionAuth's hosted login pages.
As mentioned in previous discussions, the current documentation doesn't provide a way to pass the PKCE
code_verifierwhen requesting the "Complete an OpenID Connect Login" endpoint.I'd like to propose two improvements:
Allow passing
code,code_verifier(optional), andredirect_uriin the request payload. This would provide a more flexible and allow the usage of PKCE; -
Allow passing an access
tokendirectly. This would eliminate the need for FusionAuth process the exchange step, similar to how Facebook's identity provider works (for example). This would probably also require the configuration of an endpoint to fetch the useremailorusername.
As a side note, since discord
access_tokenis not a JWT I believe this cannot be done using the "External JWT" identity provider.Hope you can help me with this.
Thanks! -
