    reset fusionauth using the cli
    Comments & Feedback
    2.2k
    • N
      nicholas.tsaoucis
      how can i reset fusionauth using the CLI?
      I tried to do it using a kickstart file and it failed, and now i am locked out of the system as the users didnt create correctly.
      Is there a way to reset it again using the cli?
        dan @nicholas.tsaoucis
        @nicholas-tsaoucis
        Sorry to hear that!
        You should be able to use the API key from the kickstart file to reset the password of a user. The easiest way is probably to use the Update User API: https://fusionauth.io/docs/v1/tech/apis/users#update-a-user
        N 1 Reply Last reply Reply Quote 0
        • N
          nicholas.tsaoucis @dan
          @dan no, I mean to do a reset of the entire fusionauth.
          It's ok we worked out the easiest way was dumping the db and letting it all get regenerated. and going from there.
            @nicholas-tsaoucis Glad you figured it out, thanks for closing the loop!
