    How to set the default for "Keep me signed in"
    5
    2.6k
    • G
      gg-dev
      I'd like this to be off by default, as I think that it's more secure this way. How do I set the default?
        dan @gg-dev
        @gg-dev
        I think the correct approach is to modify your template: https://fusionauth.io/docs/v1/tech/themes/template-variables#oauth-authorize
        set rememberDevice to false. You could even hide it and never let the user set it to true.
        G M 2 Replies Last reply Reply Quote 1
        • G
          gg-dev @dan
          @dan
          Sorry about the delayed reply, I forgot to sub again (I've turned this on by default now in the forum).
          I did try to modify the template, but IIRC (it was a while ago now), it didn't persist correctly after a failed submission, and I got really confused by the logic in _input_checkbox.
          I might try again in future, but right now it's not a high priority.
          Thanks.
          • M
            mo.mustkem @dan
            @dan
            Could you please assist what is the correct place to set this variable?
            • Assign this variable inside template
              [#assign rememberDevice = false /]
            Or
            • Can be set false from Admin panel?
            Any help is greatly appreciated. Thanks!
              mark.robustelli @mo.mustkem
              @mo-mustkem It is a Theme Template Variable. Please check out https://fusionauth.io/docs/customize/look-and-feel/template-variables#oauth-authorize. rememberDevice is in /oauth2/authorize
