    Performance issues after upgrade
    2.7k
    • P
      paul.fink
      Hi,
      We upgraded from 1.40.2 to 1.41.3 and are seeing massive performance issues. Everything is very slow. Signing in, clicking on any pages in the admin side takes several seconds. Doing an api call to get a user takes over 6 seconds.
      The only error in the logs I am seeing is this one:
      2022-11-25T07:54:57.944-07:00	java.io.IOException: Broken pipe
      2022-11-25T07:54:57.944-07:00	at java.base/sun.nio.ch.FileDispatcherImpl.writev0(Native Method)
      2022-11-25T07:54:57.944-07:00	at java.base/sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:66)
      2022-11-25T07:54:57.944-07:00	at java.base/sun.nio.ch.IOUtil.write(IOUtil.java:217)
      2022-11-25T07:54:57.944-07:00	at java.base/sun.nio.ch.IOUtil.write(IOUtil.java:153)
      2022-11-25T07:54:57.944-07:00	at java.base/sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:563)
      2022-11-25T07:54:57.944-07:00	at java.base/java.nio.channels.SocketChannel.write(SocketChannel.java:642)
      2022-11-25T07:54:57.944-07:00	at io.fusionauth.http.server.HTTPServerThread.write(HTTPServerThread.java:298)
      2022-11-25T07:54:57.944-07:00	at io.fusionauth.http.server.HTTPServerThread.run(HTTPServerThread.java:158)
      We run this in a docker container in aws. I have tried running more instances of it but that did not change anything. CPU load will get high if anyone tries to do more than one thing with the system. Memory stays the same. Any ideas on what we can do or what changed?
      P 1 Reply Last reply Reply Quote 1
      • P
        paul.fink @paul.fink
        I would like to add that we have a production instance that is running with less resources with no issues. The production instance has way less users, groups, registrations, applications, etc. So the data seems to have something to do with it.
        • joshuaJ
          joshua @paul.fink
          @paul-fink marking this thread as being addressed out of this forum band.
          -Josh
