    Kickstart and lambdas and newlines
    kickstart lambda
    3.1k
      I'm using kickstart to set up my FusionAuth instances.
      Only issue i ran into was posting a lambda body. looks like FusionAuth does some ‘\n’ replacement in the kickstart process. The lambdas created using kickstart have newlines stripped.
      Creating a lambda using the API (post for example) works fine, (respects newlines). The lambda appears to work, so this isn't a critical issue.
      But is there a way to preserve newlines?
        Can you use an include for the function body? For example: (where myLambda.ftl is your Lambda function in a folder named lambdas)
        "lambda":{
           "body":  "@{lambdas/myLambda.ftl}",
        That should preserve your line returns if you include it that way. Hope that helps!
