    Can we make enabling of 2FA required after login for specific users of application?
    1.3k
      jvadaliya
      Hi,
      I have one application with many users. I want to make 2FA mandatory for specific users. So that the next time whenever those users logged in, then they can not access the application without enabling 2FA.
      How can we achieve that? Is this possible?
        dan @jvadaliya
        @jvadaliya FusionAuth enforces MFA for users at the tenant or application level, but not the specific user.
        You can file a feature request here: https://github.com/fusionauth/fusionauth-issues/issues
        You can also make an API call in your application after the user has logged in to force MFA for only certain users; this is called step up auth: https://fusionauth.io/docs/v1/tech/guides/multi-factor-authentication#step-up-auth
        Hope this helps.
        • System referenced this topic on
