    SAML v2 identity provider fails using RSA-SHA
    2.2k
      mark.robustelli
      SAML v2 identity provider fails using RSA-SHA1
        mark.robustelli
        JDK 17 turned off RSA-SHA1 XML signature support. It can be re-enabled by modifying java.security file in the JDK conf/security folder.
        This is addressed in the release notes and Github issue 1814.
