    Settings?
    3.8k
    • E
      ecamacho
      I've followed the 5 minute get started, but noticed I don't have a "Settings" option on the left hand menu. I've checked that my user is admin. What step did I miss? I
        Hiya,
        Can you share a screenshot and version number? Settings is toward the bottom so depending on your screen resolution, it's possible you may need to scroll.
        • E
          ecamacho
          Wow. You are right. Apologies. I'm doing some work on an older laptop and with the resolution and the lack of contrast on the LCD, I didn't notice the scrolling. Thanks!
