    MFA web hooks
    2.1k
    • H
      harish_reddy
      Should not the web hooks for MFA be part of MFA feature?
        dan @harish_reddy
        Hiya @harish_reddy !
        Webhooks for MFA enablement are an enterprise feature, like many of the advanced security features (IP ACLs, some email workflows, rate limiting). These webhooks are often ingested into a SIEM (Security information and event management) system for threat monitoring, which is an enterprisey thing to need to do. Similarly, the ability to apply MFA policies to a given application is restricted to the enterprise license.
        You can enable and enforce MFA methods at the starter/essentials, but you don't get any of the enterprise webhooks unless you purchase an enterprise license.
        Hope that helps clarify things and sorry for the confusion.
        You can find all of our features broken out by plan here: https://fusionauth.io/docs/get-started/core-concepts/editions-features
        If you have further questions, feel free to contact our technical sales team: https://fusionauth.io/contact
        H 1 Reply Last reply Reply Quote 0
        • H
          harish_reddy @dan
          @dan
          This is one use case. Agreed.
          There might be some applications where UI has to update based on user actions related to MFA on fusionauth pages.
          We are using some work arounds for now. But, I think without these webhooks, MFA is incomplete feature.
            dan @harish_reddy
            @harish_reddy Thanks for the feedback, we appreciate it. While I think it is unlikely we'd separate out those webhooks, you are welcome to add a GH issue with your feedback and we can see how others in the community feel about the topic.
