    Is there a way to enable or disable captcha at application level?
    6.9k
    • M
      muditshukla3
      Looking at the documentation I came across captcha settings at Tenant level. I was wondering, if I have multiple applications under a single Tenant, is there a way to enable or disable captcha at application level?
        mark.robustelli @muditshukla3
        @muditshukla3 you can. Please check out this blog. https://fusionauth.io/blog/announcing-fusionauth-1-37#configure-mfa-requirements-for-an-application
          dan @mark.robustelli
          @mark-robustelli I don't believe you can do this. I think @muditshukla3 was asking about CAPTCHA, not MFA.
            dan @dan
            See also https://fusionauth.io/community/forum/topic/2749/can-you-turn-off-captcha-for-certain-applications-in-a-tenant which has some workarounds.
              mark.robustelli @dan
              @dan Great catch, no sure how I confused mfa and captcha. Thank you!
