    Understanding FusionAuth System Log Exceptions and Their Impact
    • W
      wesley
      When reviewing FusionAuth System Logs, we see several instances of exception codes such as “ExceptionExceptionHandler - An unhandled exception was thrown” or “StaticResourceWorkflow - Unable to load static resource” or “HTTP worker threw an exception while processing a request.” Does this indicate something that needs to be fixed?
      • W
        wesley @wesley
        No, these exceptions are typically innocuous and indicate that the client closed the connection before FusionAuth could complete writing a response. For example, this can happen when a user navigates away while a page is still loading.
