    Enabling MFA for All Users or Specific Projects in FusionAuth Essentials Plan
    mfa
    2.7k
    • W
      wesley
      We are currently on the Essentials plan and want to know if this allows us to to have multi-factor authentication enabled for our whole universe of users. If so, are we able to enable MFA on a project by project basis or is it just for the whole tenant?
      • W
        wesley @wesley
        With the Essentials plan, you do have MFA available to you on a Tenant level under Tenant>Multi-Factor. To have users set up MFA you either need to set MFA to Required, where users will need to set up MFA to complete a login or you will need to enable the “Self Service Account Management” page so users can visit it to set up MFA. So you can set up MFA for any Tenant to make it available to users.
        https://fusionauth.io/docs/lifecycle/authenticate-users/multi-factor-authentication
        https://fusionauth.io/docs/lifecycle/manage-users/account-management/
        In order to change MFA settings at the Application level for enabling MFA on a project by project basis, you would need to upgrade to the Enterprise plan.
