    Securing React Native with OAuth Question
    10.6k
    • D
      danielvu1000
      Hey everyone, I have seemed to encounter an issue with following this guide. I have been able to integrate fusionauth;however, there is only one issue. Whenever I finish logging in, I don't seem to get redirected to anywhere. I am following the redirection scheme mentioned in the guide as well. Anyone have any ideas?
      D 1 Reply Last reply Reply Quote 0
      • D
        danielvu1000 @danielvu1000
        nvm, I have figured out the issue. I had to make sure the url scheme was set correctly for the redirection url
          Ah, great, thanks. Do I need to update the blog post? Was there an error in the instructions?
          • D
            danielvu1000 @dan
            @dan You're fine, i just read something wrong
