    Start FusionAuth from docker in productive mode fails
    2.3k
    • C
      cyrill.lippuner
      I have installed fusionauth+postgres with docker on an ubuntu server. Everything works fine, but as soon as I want to enable productive mode, FusionAuth does not start anymore. I am using an nginx proxy, but the communication between fusionauth and the database happens inside the docker network.
      I have following logs:
      root@dev1:~/launch# ./sh/local-iam-maintenance
      Creating volume "launch_fa_config" with default driver
      Creating volume "launch_web-root" with local driver
      Creating fusionauthdb ... done
      Creating fusionauth   ... done
      Creating webserver    ... done
      Attaching to fusionauthdb, fusionauth, webserver
      fusionauth      | NOTE: Picked up JDK_JAVA_OPTIONS:  --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
      fusionauthdb    |
      fusionauthdb    | PostgreSQL Database directory appears to contain a database; Skipping initialization
      fusionauthdb    |
      fusionauthdb    | 2021-01-19 12:17:34.854 UTC [1] LOG:  listening on IPv4 address "0.0.0.0", port 5432
      fusionauthdb    | 2021-01-19 12:17:34.854 UTC [1] LOG:  listening on IPv6 address "::", port 5432
      fusionauthdb    | 2021-01-19 12:17:34.858 UTC [1] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
      fusionauthdb    | 2021-01-19 12:17:34.881 UTC [20] LOG:  database system was shut down at 2021-01-19 12:16:47 UTC
      fusionauthdb    | 2021-01-19 12:17:34.892 UTC [1] LOG:  database system is ready to accept connections
      webserver       | /docker-entrypoint.sh: /docker-entrypoint.d/ is not empty, will attempt to perform configuration
      webserver       | /docker-entrypoint.sh: Looking for shell scripts in /docker-entrypoint.d/
      webserver       | /docker-entrypoint.sh: Launching /docker-entrypoint.d/10-listen-on-ipv6-by-default.sh
      webserver       | 10-listen-on-ipv6-by-default.sh: info: Getting the checksum of /etc/nginx/conf.d/default.conf
      webserver       | 10-listen-on-ipv6-by-default.sh: info: Enabled listen on IPv6 in /etc/nginx/conf.d/default.conf
      webserver       | /docker-entrypoint.sh: Launching /docker-entrypoint.d/20-envsubst-on-templates.sh
      webserver       | /docker-entrypoint.sh: Configuration complete; ready for start up
      fusionauth      | 19-Jan-2021 12:17:36.900 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib]
      fusionauth      | 19-Jan-2021 12:17:37.280 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-9011"]
      fusionauth      | 19-Jan-2021 12:17:37.305 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
      fusionauth      | 19-Jan-2021 12:17:37.359 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["https-jsse-nio-9013"]
      fusionauth      | 19-Jan-2021 12:17:37.750 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
      fusionauth      | 19-Jan-2021 12:17:37.754 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-127.0.0.1-9019"]
      fusionauth      | 19-Jan-2021 12:17:37.758 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
      fusionauth      | 19-Jan-2021 12:17:37.761 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1373 ms
      fusionauth      | 19-Jan-2021 12:17:37.771 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
      fusionauth      | 19-Jan-2021 12:17:37.773 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.57
      fusionauth      | Jan 19, 2021 12:17:39 PM org.apache.jasper.servlet.TldScanner scanJars
      fusionauth      | INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
      fusionauth      | 2021-01-19 12:17:40.331 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/usr/local/fusionauth/config/fusionauth.properties]
      fusionauth      | 2021-01-19 12:17:40.336 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Set property [fusionauth-app.url] set to [http://fusionauth:9011] using configured value.
      fusionauth      | 2021-01-19 12:17:40.343 PM ERROR org.primeframework.mvc.guice.GuiceBootstrap -
      fusionauth      |
      fusionauth      | ===================================================================================================
      fusionauth      |
      fusionauth      |   Unable to start the server. Here's why:
      fusionauth      |
      fusionauth      |
      fusionauth      | [Error injecting constructor, java.lang.UnsupportedOperationException]
      fusionauth      |        -> [class java.lang.UnsupportedOperationException] null
      fusionauth      |
      fusionauth      |
      fusionauth      |
      fusionauth      | 2021-01-19 12:17:40.352 PM ERROR org.primeframework.mvc.guice.GuiceBootstrap - Unable to start the server. Exception:
      fusionauth      |
      fusionauth      | com.google.inject.CreationException: Unable to create injector, see the following errors:
      fusionauth      |
      fusionauth      | 1) Error injecting constructor, java.lang.UnsupportedOperationException
      fusionauth      |   at io.fusionauth.api.configuration.DefaultFusionAuthConfiguration.<init>(DefaultFusionAuthConfiguration.java:58)
      fusionauth      |   at io.fusionauth.api.configuration.DefaultFusionAuthConfiguration.class(DefaultFusionAuthConfiguration.java:23)
      fusionauth      |   while locating io.fusionauth.api.configuration.DefaultFusionAuthConfiguration
      fusionauth      |   at io.fusionauth.app.maintenance.guice.FusionAuthInitialMaintenanceModeModule.configure(FusionAuthInitialMaintenanceModeModule.java:19)
      fusionauth      |   while locating io.fusionauth.api.configuration.FusionAuthConfiguration
      fusionauth      |
      fusionauth      | 1 error
      fusionauth      |        at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:554)
      fusionauth      |        at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:188)
      fusionauth      |        at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:111)
      fusionauth      |        at com.google.inject.Guice.createInjector(Guice.java:87)
      fusionauth      |        at com.google.inject.Guice.createInjector(Guice.java:69)
      fusionauth      |        at com.google.inject.Guice.createInjector(Guice.java:59)
      fusionauth      |        at org.primeframework.mvc.guice.GuiceBootstrap.initialize(GuiceBootstrap.java:58)
      fusionauth      |        at com.inversoft.maintenance.servlet.MaintenanceModePrimeServletContextListener.contextInitialized(MaintenanceModePrimeServletContextListener.java:39)
      fusionauth      |        at io.fusionauth.app.primeframework.FusionAuthAppPrimeServletContextListener.contextInitialized(FusionAuthAppPrimeServletContextListener.java:26)
      fusionauth      |        at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4689)
      fusionauth      |        at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5155)
      fusionauth      |        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
      fusionauth      |        at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1412)
      fusionauth      |        at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1402)
      fusionauth      |        at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
      fusionauth      |        at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
      fusionauth      |        at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
      fusionauth      |        at java.base/java.lang.Thread.run(Thread.java:832)
      fusionauth      | Caused by: java.lang.UnsupportedOperationException: null
      fusionauth      |        at io.fusionauth.api.domain.RuntimeMode.fromConfiguration(RuntimeMode.java:21)
      fusionauth      |        at io.fusionauth.api.configuration.DefaultFusionAuthConfiguration.initialize(DefaultFusionAuthConfiguration.java:181)
      fusionauth      |        at com.inversoft.configuration.BasePropertiesFileInversoftConfiguration.initializeAndLogWarningsAndErrors(BasePropertiesFileInversoftConfiguration.java:514)
      fusionauth      |        at com.inversoft.configuration.BasePropertiesFileInversoftConfiguration.<init>(BasePropertiesFileInversoftConfiguration.java:88)
      fusionauth      |        at io.fusionauth.api.configuration.DefaultFusionAuthConfiguration$$FastClassByGuice$$b82219af.newInstance(<generated>)
      fusionauth      |        at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89)
      fusionauth      |        at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
      fusionauth      |        at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91)
      fusionauth      |        at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
      fusionauth      |        at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
      fusionauth      |        at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:168)
      fusionauth      |        at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:39)
      fusionauth      |        at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:62)
      fusionauth      |        at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:213)
      fusionauth      |        at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:184)
      fusionauth      |        ... 16 common frames omitted
      fusionauth      | Jan 19, 2021 12:17:40 PM org.apache.catalina.core.StandardContext listenerStart
      fusionauth      | SEVERE: Exception sending context initialized event to listener instance of class [io.fusionauth.app.primeframework.FusionAuthAppPrimeServletContextListener]
      fusionauth      | org.primeframework.mvc.PrimeException
      fusionauth      |        at org.primeframework.mvc.guice.GuiceBootstrap.initialize(GuiceBootstrap.java:77)
      fusionauth      |
      fusionauth      | 19-Jan-2021 12:17:40.355 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
      fusionauth      | 19-Jan-2021 12:17:40.376 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [] startup failed due to previous errors
      fusionauth      | Jan 19, 2021 12:17:40 PM org.apache.catalina.core.StandardContext listenerStop
      fusionauth      | SEVERE: Exception sending context destroyed event to listener instance of class [io.fusionauth.app.primeframework.FusionAuthAppPrimeServletContextListener]
      fusionauth      | java.lang.NullPointerException
      fusionauth      |        at org.primeframework.mvc.guice.GuiceBootstrap.shutdown(GuiceBootstrap.java:88)
      fusionauth      |        at org.primeframework.mvc.servlet.PrimeServletContextListener.contextDestroyed(PrimeServletContextListener.java:47)
      fusionauth      |        at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4735)
      fusionauth      |        at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5399)
      fusionauth      |        at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:257)
      fusionauth      |        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:187)
      fusionauth      |
      fusionauth      | 19-Jan-2021 12:17:40.434 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-9011"]
      fusionauth      | 19-Jan-2021 12:17:40.447 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["https-jsse-nio-9013"]
      fusionauth      | 19-Jan-2021 12:17:40.451 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-127.0.0.1-9019"]
      fusionauth      | 19-Jan-2021 12:17:40.454 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 2692 ms
      and using following docker-compose file:
      version: '3.7'
      services:
        fusionauthdb:
          container_name: fusionauthdb
          image: postgres:11.9-alpine
          environment:
            PGDATA: /var/lib/postgresql/data/pgdata
            POSTGRES_USER: postgres
            POSTGRES_PASSWORD: postgres
          networks:
            - app-network
          restart: unless-stopped
          volumes:
            - /var/lib/postgresql:/var/lib/postgresql/data
        fusionauth:
          image: fusionauth/fusionauth-app:1.22.2
          depends_on:
            - fusionauthdb
          environment:
            DATABASE_URL: jdbc:postgresql://fusionauthdb:5432/fusionauth
            DATABASE_ROOT_USERNAME: postgres
            DATABASE_ROOT_PASSWORD: postgres
            DATABASE_USERNAME: fusionauth
            DATABASE_PASSWORD: hkaLBM3RVnyYeYeqE3WI1w2e4Avpy0Wd5O3s3
            FUSIONAUTH_APP_MEMORY: '512M'
            FUSIONAUTH_APP_RUNTIME_MODE: development
            FUSIONAUTH_APP_URL: http://fusionauth:9011
            SEARCH_TYPE: database
          networks:
           - app-network
          ports:
            - 9011:9011
          volumes:
            - fa_config:/usr/local/fusionauth/config
      volumes:
        fa_config:
      networks:
        app-network:
          driver: bridge
      I do not really understand the error message and what is going wrong.
      Thank you for your help!
      Cyrill
        @cyrill-lippuner
        Hmmm. The docker-compose you shared shows you are still in development mode: FUSIONAUTH_APP_RUNTIME_MODE: development.
        Not sure if this is a typo, but you want to be in production mode, not productive mode. (Although we all want to be productive 🙂 ).
        Can you please try with FUSIONAUTH_APP_RUNTIME_MODE: production and share what the results are?
        • C
          cyrill.lippuner
          Yeah, that was it... I guess it was already late 😉
