    Single application for multi tenants
    1.0k
      joey
      Hello,
      We have a single mobile application with many customers (organizations).
      We would like to use FusionAuth to authenticate and authorize clients requests in a way that each customer(organization) is a different tenant.
      Is it possible to share application between tenants? If not, how can we achieve that?
      Joey.
        You cannot share FusionAuth applications between tenants, unfortunately. They are a tenant scoped object.
        If you want to sync application settings across tenants, you can use a client library or the API to script changes.
        Hope that helps!
