    Using a non-default schema on a custom postgres DB
    2.1k
    • C
      cyrill.lippuner
      Hi, I have been using the local docker setup for fusionauth with a local postgres db until now. Now I wanted to switch to a hosted DB solution, where I do not want to give the root passwords to the fusionauth app, but instead set up the DB schema manually. This worked so far without any problems, but I was wondering whether I could install the DB schema as a non-default schema instead of using the public schema which is provided by the DB at launch?
      I was able to set it up and create a user, but the connection url jdbc:postgresql://db:5432/fusionauth and the config files do not provide the possibility to select a specific schema on the DB and default automatically to public.
      Such as
      CREATE SCHEMA my_fusionauth_schema
          AUTHORIZATION postgres;
      ALTER DEFAULT PRIVILEGES IN SCHEMA my_fusionauth_schema
      GRANT INSERT, SELECT, UPDATE, DELETE ON TABLES TO fusionauth;
      Thank you for your answer ansd clarifications.
      Cyrill
        Hmm. I don't know. Is there a way to specify the schema on the JDBC URL?
        https://stackoverflow.com/a/4820666/203619 looks promising, that's what I'd try.
        • C
          cyrill.lippuner
          This is something I have already tried ad did not work. At least not with my setup. I have changed my setup and use now two databases instead of two schemas.
            Excellent, thanks for looping back. If you'd like, feel free to file an issue about supporting non public postgresql schemas: https://github.com/fusionauth/fusionauth-issues/issues
              jackehedaya
              I was able to get this working with:
              jdbc:postgresql://db:5432/mydb?currentSchema=auth
