Hi all, is it possible to see a report about different login methods?
I want to get a feel for how many users use which method (normal sign in, passwordless, different identity providers) to understand how the system is being used.
There's no built in reporting for login methods.
If you think that'd be worthwhile, please file a github issue with more details about the use case.
However, you could set up a webhook on the login event and record the
event.authenticationTypein an external datastore. -
