@mark-robustelli thanks Mark. I've upvoted and added a comment also, i'll reach out to TikTok too but most likely it'll fall on death ears
A
Posts made by adam.rahman
RE: Is it possible to add a custom identity provider or modify OpenID Connect?posted in Q&A
I am looking into using FusionAuth. We have a business need for TikTok login, it seems they don't follow the OpenID standard requiring a client_key in place of the usual client_id so using the Add OpenID Connect option does not work.
Does someone more knowledgable know if it's possible for me to create a custom identity provider, modify the OpenID Connect one or support it in some other way? Any help would be greatly appreciated
