    2. amith.kumar.shetty
    A
    • Topics 2
    • Posts 3
    • Best 1
    Posts made by amith.kumar.shetty
    • RE: Ubanle to use database with @in the username
      @dan Thank you. I had to manually run the CREATE ROLE “postgresql@hostxxxx” LOGIN PASSWORD 'yyyyyyyyyy' on my database instance before starting the app. Then everything works ok. Note the double quotes around the username
      posted in Q&A
      A
      amith.kumar.shetty
    • Ubanle to use database with @in the username
      I am connecting to postgres hosted on azure . Azure postgres requires the username to be specfied in username@hostname format. If I set the username like this, I get an error while starting the app.
      com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Exception caught executing [CREATE ROLE xxxxx@hostame WITH LOGIN PASSWORD xxxxxxxx]
      org.postgresql.util.PSQLException: ERROR: syntax error at or near "@"
        Position: 23
      Any method to fix this?
      posted in Q&A
      A
      amith.kumar.shetty
