    2. ivor.didovic.88
    I
    • Topics 1
    • Posts 2
    • Best 0
    Posts made by ivor.didovic.88
    • RE: SSO Session expiration time
      Hi @dan,
      Thank you for your answer.
      FusionAuth version is 1.23.3.
      This is my configuration:
      • Default tenant:
        • Session timeout: 31536000s
        • JWT duration: 3600s
        • Refresh Token duration: 43200min
        • FusionAuth app:
          • JWT duration: 60s
          • Refresh Token duration: 60min
      • MyTenant:
        • JWT duration: 60s
        • App1:
          • No specific JWT configuration
        • App2:
          • No Specific JWT configuration
        • App3:
          • JWT Duration: 3600s
          • Refresh Token duration: 525600min
      Can you explain to me what all does affect the SSO session duration?
      I thought I just need to set Session timeout of the "MyTenant" tenant and that will keep my SSO session for applications from that tenant until "Single sign-on" refresh token expires (and, of course, if I renew "App specific refresh token"). As I can see, Session timeout defines expiration time of the "Single sign-on" refresh token (User > Sessions) but looks like in my case "Single sign-on" refresh token is deleted after 1h (but its expiration time is 365days). So...
      • I login to App1 ==> App1 refresh token is created and "Single sign-on" refresh token is created
      • I go to App2 (I'm already logged in) ==> App2 refresh token is created
      • After ~1h, "Single sign-on" refresh token is deleted, App1 and App2 refresh tokens are still there and I can use them to fetch new access tokens until until they expire
      posted in General Discussion
      I
      ivor.didovic.88
    • SSO Session expiration time
      Hi,
      I've started using FusionAuth for handling SSO in my application but looks like my SSO session is dropped after some short time ~1h, but Session timeout for the tenant is set to 10 days and Refresh Token duration is set to 30 days.
      When I login to one of the applications from "MyTenant" I can see refresh token for the "MyApplication" application and one additional refresh token for application "Single sign-on". After ~1h of browser inactivity, this token disappears.
      Any idea what am I missing here?
      Thank you!
      I
      ivor.didovic.88
