@dan Hi,
I don't think its certificate.
When i have time, i'll test it with and without certificates and see how i goes.
Posts made by j.smutek
RE: Docker - Unable to create api key - buffer overflowposted in Q&A
RE: Docker - Unable to create api key - buffer overflowposted in Q&A@dan Hi,
 sorry about late reply.
 No i have created 1 application, 1 tenant, 1 user and no webhooks, the rest is default.
 After clean install (removed containers, volumes and images).
 I can create api key.
 Here is current docker usage, is it possible that https increases memory requirements?
 What are actual system requirements? (512MB stated in doc is not enougth)CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS 12f3678eddb5 fusionauth-fusionauth-1 0.17% 944.3MiB / 3.812GiB 24.19% 4.25MB / 1.78MB 63.7MB / 553kB 119 63fa5b302d5b fusionauth-db-1 0.00% 48.48MiB / 3.812GiB 1.24% 1.04MB / 3.92MB 15.5MB / 65.3MB 17 6206fdf53f93 fusionauth-search-1 0.94% 839.8MiB / 3.812GiB 21.51% 40.4MB / 254kB 27.3MB / 174MB 72
 After disabling https, I was unable to login to webUI as i was redirected back to login screenUrl after redirect: /oauth2/authorize?client_id=3c219e58-ed0e-4b18-ad48-f4f92793ae32&response_type=code&redirect_uri=%2Fadmin%2Flogin&scope=offline_access&code_challenge=aAjtN7cCeIcKGNy98zdKVJLQGiFAhjE90WA3NeOkvH0&code_challenge_method=S256&state=iCNptKF_HgM7P_H74jFphFI_9pHzJ0gIu77LYPxNr0owith front end error: Authorize.js?version=1.48.1:34 Uncaught ReferenceError: PublicKeyCredential is not defined at new FusionAuth.OAuth2.Authorize (Authorize.js?version=1.48.1:34:43) at authorize?client_id=3c219e58-ed0e-4b18-ad48-f4f92793ae32&response_type=code&redirect_uri=%2Fadmin%2Flogin&scope=offline_access&code_challenge=_Y6KAh3_n1H6hJB0yrTtbmhB-AtWm_0VpQf4xF7tHEE&code_challenge_method=S256&state=iLC0KrVXMrQ9BH63SYOQX7Q7QazQa8CVWiUx-YK8ZH0:78:9 at HTMLDocument.value (PrimeDocument.js:377:9)I will try after clean install.
 Here is more info that could help.
 Api key creation screen:
 After clicking on save, end of url changes to "/admin/api-key/add" with ERR_EMPTY_RESPONSEHere is log from start of fisionauth to me trying to create api key: fusionauth-fusionauth-1 | --------------------------------------------------------------------------------------------------------- fusionauth-fusionauth-1 | --------------------------------- Starting FusionAuth version [1.47.1] ---------------------------------- fusionauth-fusionauth-1 | --------------------------------------------------------------------------------------------------------- fusionauth-fusionauth-1 | fusionauth-fusionauth-1 | 2023-10-25 05:54:06.220 AM INFO io.fusionauth.api.plugin.guice.PluginModule - No plugins found fusionauth-fusionauth-1 | 2023-10-25 05:54:06.420 AM INFO io.fusionauth.api.service.system.NodeService - Node [78094893-7c22-447e-ad2e-8ab48cc5231f] started. fusionauth-fusionauth-1 | 2023-10-25 05:54:06.928 AM INFO io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/usr/local/fusionauth/config/fusionauth.properties] fusionauth-fusionauth-1 | 2023-10-25 05:54:06.929 AM INFO io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Set property [fusionauth-app.url] set to [http://fusionauth:9011] using configured value. fusionauth-fusionauth-1 | 2023-10-25 05:54:06.930 AM INFO com.inversoft.configuration.BasePropertiesFileInversoftConfiguration - fusionauth-fusionauth-1 | - Overriding default value of property [database.mysql.enforce-utf8mb4] with value [true] fusionauth-fusionauth-1 | - Overriding default value of property [FUSIONAUTH_APP_RUNTIME_MODE] with value [development] fusionauth-fusionauth-1 | - Overriding default value of property [SEARCH_TYPE] with value [elasticsearch] fusionauth-fusionauth-1 | fusionauth-fusionauth-1 | 2023-10-25 05:54:06.932 AM INFO com.inversoft.jdbc.hikari.DataSourceProvider - Connecting to PostgreSQL database at [jdbc:postgresql://db:5432/fusionauth] fusionauth-fusionauth-1 | 2023-10-25 05:54:06.933 AM WARN com.zaxxer.hikari.HikariConfig - HikariPool-1 - idleTimeout has been set but has no effect because the pool is operating as a fixed size pool. fusionauth-fusionauth-1 | 2023-10-25 05:54:06.935 AM INFO com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Starting... fusionauth-fusionauth-1 | 2023-10-25 05:54:06.955 AM INFO com.zaxxer.hikari.pool.HikariPool - HikariPool-1 - Added connection org.postgresql.jdbc.PgConnection@243bf087 fusionauth-fusionauth-1 | 2023-10-25 05:54:06.965 AM INFO com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Start completed. fusionauth-fusionauth-1 | 2023-10-25 05:54:08.234 AM INFO com.inversoft.scheduler.DefaultScheduler - Starting up scheduler fusionauth-fusionauth-1 | 2023-10-25 05:54:08.236 AM INFO com.inversoft.scheduler.DefaultScheduler - Scheduler is running fusionauth-fusionauth-1 | 2023-10-25 05:54:08.370 AM INFO com.inversoft.search.ElasticRestClientHelper - Connecting to Elasticsearch at [http://search:9200] fusionauth-fusionauth-1 | 2023-10-25 05:54:08.385 AM INFO io.fusionauth.api.service.system.NodeService - Node [78094893-7c22-447e-ad2e-8ab48cc5231f] added with address [http://fusionauth:9011] fusionauth-fusionauth-1 | 2023-10-25 05:54:09.159 AM INFO io.fusionauth.api.service.system.NodeService - Node [78094893-7c22-447e-ad2e-8ab48cc5231f] promoted to master at [2023-10-25T05:54:09.159586852Z], the previous master Node [76a0b959-f6fa-4085-b64f-7df990611db7] has been shutdown or removed fusionauth-fusionauth-1 | 2023-10-25 05:54:09.481 AM INFO io.fusionauth.app.primeframework.FusionHTTPContextAuthSetup - Initializing the FusionAuth HTTP Context. fusionauth-fusionauth-1 | 2023-10-25 05:54:09.553 AM INFO com.inversoft.search.ElasticRestClientHelper - Connecting to Elasticsearch at [http://search:9200] fusionauth-fusionauth-1 | 2023-10-25 05:54:09.646 AM INFO org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime fusionauth-fusionauth-1 | 2023-10-25 05:54:09.653 AM INFO org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime fusionauth-fusionauth-1 | 2023-10-25 05:54:09.653 AM INFO org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime fusionauth-fusionauth-1 | 2023-10-25 05:54:09.659 AM INFO io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up! fusionauth-fusionauth-1 | 2023-10-25 05:54:09.669 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server listening on port [9011] fusionauth-fusionauth-1 | 2023-10-25 05:54:09.670 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server started successfully fusionauth-fusionauth-1 | 2023-10-25 05:54:09.670 AM INFO io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up! fusionauth-fusionauth-1 | 2023-10-25 05:54:09.671 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server listening on port [9012] fusionauth-fusionauth-1 | 2023-10-25 05:54:09.671 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server started successfully fusionauth-fusionauth-1 | 2023-10-25 05:54:09.671 AM INFO io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up! fusionauth-fusionauth-1 | 2023-10-25 05:54:09.672 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server listening on port [9013] fusionauth-fusionauth-1 | 2023-10-25 05:54:09.672 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server started successfully fusionauth-fusionauth-1 | 2023-10-25 05:55:15.340 AM INFO com.inversoft.search.ElasticSearchClient - Determine version of the search engine. fusionauth-fusionauth-1 | 2023-10-25 05:55:15.348 AM WARN org.elasticsearch.client.RestClient - request [GET http://search:9200/] returned 1 warnings: [299 Elasticsearch-7.17.0-bee86328705acaa9a6daede7140defd4d9ec56bd "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."] fusionauth-fusionauth-1 | 2023-10-25 05:55:15.350 AM INFO com.inversoft.search.ElasticSearchClient - Reported version [7.17.0] fusionauth-fusionauth-1 | 2023-10-25 05:55:15.353 AM INFO com.inversoft.search.ElasticSearchClient - Set major version to [7] fusionauth-fusionauth-1 | 2023-10-25 05:55:15.419 AM WARN org.elasticsearch.client.RestClient - request [PUT http://search:9200/fusionauth_user/_doc/91032242-efb0-4a2b-a38a-c8bb7c9d7243] returned 1 warnings: [299 Elasticsearch-7.17.0-bee86328705acaa9a6daede7140defd4d9ec56bd "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."] fusionauth-fusionauth-1 | 2023-10-25 05:55:15.917 AM WARN org.elasticsearch.client.RestClient - request [PUT http://search:9200/fusionauth_user/_doc/91032242-efb0-4a2b-a38a-c8bb7c9d7243] returned 1 warnings: [299 Elasticsearch-7.17.0-bee86328705acaa9a6daede7140defd4d9ec56bd "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."] fusionauth-fusionauth-1 | 2023-10-25 05:55:48.832 AM WARN org.elasticsearch.client.RestClient - request [PUT http://search:9200/fusionauth_user/_doc/91032242-efb0-4a2b-a38a-c8bb7c9d7243] returned 1 warnings: [299 Elasticsearch-7.17.0-bee86328705acaa9a6daede7140defd4d9ec56bd "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."] fusionauth-fusionauth-1 | 2023-10-25 05:57:14.945 AM ERROR io.fusionauth.http.server.HTTPServerThread - An exception was thrown during processing fusionauth-fusionauth-1 | java.lang.IllegalStateException: A buffer overflow is not expected during an unwrap operation. This occurs because the preamble or body buffers are too small. Increase their sizes to avoid this issue. fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPS11Processor.read(HTTPS11Processor.java:191) fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPServerThread.read(HTTPServerThread.java:298) fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPServerThread.run(HTTPServerThread.java:169) fusionauth-fusionauth-1 | 2023-10-25 05:57:45.456 AM ERROR io.fusionauth.http.server.HTTPServerThread - An exception was thrown during processing fusionauth-fusionauth-1 | java.lang.IllegalStateException: A buffer overflow is not expected during an unwrap operation. This occurs because the preamble or body buffers are too small. Increase their sizes to avoid this issue. fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPS11Processor.read(HTTPS11Processor.java:191) fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPServerThread.read(HTTPServerThread.java:298) fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPServerThread.run(HTTPServerThread.java:169)Here are versions of nodejs and docker installed on my azure virtual where fusionauth docker is running: nodejs --version v20.8.0 docker --version Docker version 24.0.6, build ed223bc
 Yes i'm using docker from install guide (docker compose yml is from repo),
 Operating sys. 22.04.1-Ubuntu , kernel: 6.2.0-1014-azure #14~,
 yes it prevents api key from beaing created, .env file as i said is based on one in repo with minimum changes (***** are not real values):POSTGRES_USER=***** POSTGRES_PASSWORD=***** DATABASE_USERNAME=***** DATABASE_PASSWORD=***** ES_JAVA_OPTS="-Xms512m -Xmx512m" FUSIONAUTH_APP_MEMORY=1024M FUSIONAUTH_APP_HTTPS_ENABLED=true FUSIONAUTH_APP_HTTPS_PORT=9013 FUSIONAUTH_APP_HTTPS_CERTIFICATE_FILE=/usr/local/fusionauth/fullchain.crt FUSIONAUTH_APP_HTTPS_PRIVATE_KEY_FILE=/usr/local/fusionauth/key.key
 Hi, via admin UI (its fresh install there is no api yet), i don't need to fill anything just hit save and ti creates the error, I pasted above.
Docker - Unable to create api key - buffer overflowposted in Q&AHi,
 Im using docker version of FusionAuth version 1.47.1
 I can create/edit users and applications but not api key(s) as it cause error:fusionauth-fusionauth-1 | 2023-10-20 05:22:45.357 AM ERROR io.fusionauth.http.server.HTTPServerThread - An exception was thrown during processing fusionauth-fusionauth-1 | java.lang.IllegalStateException: A buffer overflow is not expected during an unwrap operation. This occurs because the preamble or body buffers are too small. Increase their sizes to avoid this issue. fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPS11Processor.read(HTTPS11Processor.java:191) fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPServerThread.read(HTTPServerThread.java:298) fusionauth-fusionauth-1 | at io.fusionauth.http.server.HTTPServerThread.run(HTTPServerThread.java:169)At first I used .env file from repo .env, then increased memory for app to FUSIONAUTH_APP_MEMORY=1024Mbut this didn't help. Here is screen of docker stats with running fusionauth: CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS f8fd1d7a3dda fusionauth-fusionauth-1 0.18% 907MiB / 3.812GiB 23.23% 6.26MB / 1.45MB 819kB / 1.57MB 121 8e757ef046f1 fusionauth-search-1 0.39% 830.2MiB / 3.812GiB 21.27% 12.8kB / 9.97kB 2.27MB / 88.8MB 67 867feb08bc18 fusionauth-db-1 0.19% 42.66MiB / 3.812GiB 1.09% 1.11MB / 6.06MB 7.89MB / 3.51MB 18Any way to prevent this issue?
RE: Https certificate not found by FusionAuth dockerposted in Q&A@mark-robustelli
 Thank you, problem was with missing volumes.
 Also had to convert private key from PEM (-----BEGIN RSA PRIVATE KEY-----) to PEM (-----BEGIN PRIVATE KEY-----) format.
 Now HTTPS is working.
 No, I fixed the missing letter, but problem is same.fusionauth-fusionauth-1 | Exception in thread "main" java.lang.RuntimeException: java.nio.file.NoSuchFileException: /home/testmock/fusionauth/fullchain.crt fusionauth-fusionauth-1 | at io.fusionauth.app.FusionAuthMain.getHttpsConfiguration(FusionAuthMain.java:81) fusionauth-fusionauth-1 | at io.fusionauth.app.FusionAuthMain.configuration(FusionAuthMain.java:36) fusionauth-fusionauth-1 | at org.primeframework.mvc.BasePrimeMain.start(BasePrimeMain.java:103) fusionauth-fusionauth-1 | at io.fusionauth.app.FusionAuthMain.main(FusionAuthMain.java:27) fusionauth-fusionauth-1 | Caused by: java.nio.file.NoSuchFileException: /home/testmock/fusionauth/fullchain.crt fusionauth-fusionauth-1 | at java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:92) fusionauth-fusionauth-1 | at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:106) fusionauth-fusionauth-1 | at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111) fusionauth-fusionauth-1 | at java.base/sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:218) fusionauth-fusionauth-1 | at java.base/java.nio.file.Files.newByteChannel(Files.java:380) fusionauth-fusionauth-1 | at java.base/java.nio.file.Files.newByteChannel(Files.java:432) fusionauth-fusionauth-1 | at java.base/java.nio.file.Files.readAllBytes(Files.java:3288) fusionauth-fusionauth-1 | at java.base/java.nio.file.Files.readString(Files.java:3366) fusionauth-fusionauth-1 | at java.base/java.nio.file.Files.readString(Files.java:3325) fusionauth-fusionauth-1 | at io.fusionauth.app.FusionAuthMain.getHttpsConfiguration(FusionAuthMain.java:77)
Https certificate not found by FusionAuth dockerposted in Q&AHi,
 I'm tring to get https working using FusionAuth docker, but when i start the fusionauth
 it ends with exception that it can't find certificate file.
 The certificate file exists (check it so many times).
 Any idea what needs to be done to fix this problem?Here is the exception: fusioauth-fusionauth-1 | Exception in thread "main" java.lang.RuntimeException: java.nio.file.NoSuchFileException: /home/testmock/fusioauth/fullchain.crt fusioauth-fusionauth-1 | at io.fusionauth.app.FusionAuthMain.getHttpsConfiguration(FusionAuthMain.java:81) fusioauth-fusionauth-1 | at io.fusionauth.app.FusionAuthMain.configuration(FusionAuthMain.java:36) fusioauth-fusionauth-1 | at org.primeframework.mvc.BasePrimeMain.start(BasePrimeMain.java:103) fusioauth-fusionauth-1 | at io.fusionauth.app.FusionAuthMain.main(FusionAuthMain.java:27) fusioauth-fusionauth-1 | Caused by: java.nio.file.NoSuchFileException: /home/testmock/fusioauth/fullchain.crt fusioauth-fusionauth-1 | at java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:92) fusioauth-fusionauth-1 | at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:106) fusioauth-fusionauth-1 | at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111) fusioauth-fusionauth-1 | at java.base/sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:218) fusioauth-fusionauth-1 | at java.base/java.nio.file.Files.newByteChannel(Files.java:380) fusioauth-fusionauth-1 | at java.base/java.nio.file.Files.newByteChannel(Files.java:432) fusioauth-fusionauth-1 | at java.base/java.nio.file.Files.readAllBytes(Files.java:3288) fusioauth-fusionauth-1 | at java.base/java.nio.file.Files.readString(Files.java:3366) fusioauth-fusionauth-1 | at java.base/java.nio.file.Files.readString(Files.java:3325) fusioauth-fusionauth-1 | at io.fusionauth.app.FusionAuthMain.getHttpsConfiguration(FusionAuthMain.java:77)Here is sniped of docker-compose.yml: fusionauth: image: fusionauth/fusionauth-app:latest depends_on: db: condition: service_healthy search: condition: service_healthy environment: DATABASE_URL: jdbc:postgresql://db:5432/fusionauth DATABASE_ROOT_USERNAME: ${POSTGRES_USER} DATABASE_ROOT_PASSWORD: ${POSTGRES_PASSWORD} DATABASE_USERNAME: ${DATABASE_USERNAME} DATABASE_PASSWORD: ${DATABASE_PASSWORD} FUSIONAUTH_APP_MEMORY: ${FUSIONAUTH_APP_MEMORY} FUSIONAUTH_APP_RUNTIME_MODE: development FUSIONAUTH_APP_URL: http://fusionauth:9011 SEARCH_SERVERS: http://search:9200 SEARCH_TYPE: elasticsearch FUSIONAUTH_APP_HTTPS_ENABLED: ${FUSIONAUTH_APP_HTTPS_ENABLED} FUSIONAUTH_APP_HTTPS_PORT: ${FUSIONAUTH_APP_HTTPS_PORT} FUSIONAUTH_APP_HTTPS_CERTIFICATE_FILE: ${FUSIONAUTH_APP_HTTPS_CERTIFICATE_FILE} FUSIONAUTH_APP_HTTPS_PRIVATE_KEY_FILE: ${FUSIONAUTH_APP_HTTPS_PRIVATE_KEY_FILE}Here is sniped of .env: FUSIONAUTH_APP_HTTPS_ENABLED=true FUSIONAUTH_APP_HTTPS_PORT=5000 FUSIONAUTH_APP_HTTPS_CERTIFICATE_FILE=/home/testmock/fusionauth/fullchain.crt FUSIONAUTH_APP_HTTPS_PRIVATE_KEY_FILE=/home/testmock/fusionauth/key.keyHere are visible files with permissions: testmock@testMock:~/fusionauth$ ls -la drwxrwxr-x 2 testmock testmock 4096 Oct 17 08:31 . drwxr-xr-x 34 testmock testmock 4096 Oct 17 08:31 .. -rw-rw-r-- 1 testmock testmock 410 Oct 17 08:31 .env -rw-rw-r-- 1 testmock testmock 2347 Oct 17 07:02 docker-compose.yml -rw-r--r-- 1 testmock testmock 5914 Oct 17 06:40 fullchain.crt -rw-r--r-- 1 testmock testmock 3243 Oct 17 06:41 key.key
