@mark-robustelli cheers, that was a useful post. The IAMShowcase tools did help me filter out what was correct and what was not. Eventually I found that the compression config settings on the passed request were not correct.
Posts made by james.hudson
RE: SAML authnRequest exceptionposted in General Discussion
Hello,
I am trying to implement FusionAuth as idP for an application (SuiteCRM) and am getting an error at the redirect.
I am running FusionAuth (1.62.1) in Docker for testing but get the same error on our staging instance.
The error is:
FusionAuth encountered an exception while processing the SAML v2 AuthnRequest. The request originated from: 172.19.0.1. SAMLRequest: PHNhbWxwOkF1dGhuUmVxdWVzdAogICAgeG1sbnM6c2FtbHA9InVybjpvYXNpczpuYW1lczp0YzpTQU1MOjIuMDpwcm90b2NvbCIKICAgIHhtbG5zOnNhbWw9InVybjpvYXNpczpuYW1lczp0YzpTQU1MOjIuMDphc3NlcnRpb24iCiAgICBJRD0iT05FTE9HSU5fMjdiZTYyM2QwZTBjYzEwZWMyMzgyNjZlYWRlMmQwNDc2Nzk4MzEyZiIKICAgIFZlcnNpb249IjIuMCIKICAgIFByb3ZpZGVyTmFtZT0iRXhhbXBsZSIKICAgIElzc3VlSW5zdGFudD0iMjAyNi0wMi0xOVQxNToxMzo1N1oiCiAgICBEZXN0aW5hdGlvbj0iaHR0cDovL2xvY2FsaG9zdDo5MDEzL3NhbWx2Mi9sb2dpbi9lZTBkOThiNS0wZDdjLTExZjEtODIwMC0zNjRkM2JmYzg5YWYiCiAgICBQcm90b2NvbEJpbmRpbmc9InVybjpvYXNpczpuYW1lczp0YzpTQU1MOjIuMDpiaW5kaW5nczpIVFRQLVBPU1QiCiAgICBBc3NlcnRpb25Db25zdW1lclNlcnZpY2VVUkw9Imh0dHA6Ly9sb2NhbGhvc3Qvc2FtbC9hY3MiPgogICAgPHNhbWw6SXNzdWVyPmh0dHA6Ly9sb2NhbGhvc3Qvc2FtbC9sb2dpbjwvc2FtbDpJc3N1ZXI+CiAgICA8c2FtbHA6TmFtZUlEUG9saWN5CiAgICAgICAgRm9ybWF0PSJ1cm46b2FzaXM6bmFtZXM6dGM6U0FNTDoxLjE6bmFtZWlkLWZvcm1hdDp1bnNwZWNpZmllZCIKICAgICAgICBBbGxvd0NyZWF0ZT0idHJ1ZSIgLz4KPC9zYW1scDpBdXRoblJlcXVlc3Q+ Exception: io.fusionauth.samlv2.domain.SAMLException: Invalid AuthnRequest. Inflating the bytes failed. at io.fusionauth.samlv2.util.SAMLTools.decodeAndInflate(SAMLTools.java:168) at io.fusionauth.samlv2.service.DefaultSAMLv2Service.parseRequestRedirectBinding(DefaultSAMLv2Service.java:641) at io.fusionauth.api.service.samlv2.DefaultSAMLv2ProviderService.parseAuthNRedirectRequest(DefaultSAMLv2ProviderService.java:314) at io.fusionauth.app.action.samlv2.LoginAction.lambda$get$0(LoginAction.java:101) at io.fusionauth.app.action.samlv2.BaseSAMLAction.handleSAMLException(BaseSAMLAction.java:111) at io.fusionauth.app.action.samlv2.LoginAction.get(LoginAction.java:98) at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) at java.base/java.lang.reflect.Method.invoke(Method.java:580) at org.primeframework.mvc.util.ReflectionUtils.invoke(ReflectionUtils.java:443) at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.execute(DefaultActionInvocationWorkflow.java:77) at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.perform(DefaultActionInvocationWorkflow.java:60) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.message.DefaultMessageWorkflow.perform(DefaultMessageWorkflow.java:50) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.validation.DefaultValidationWorkflow.perform(DefaultValidationWorkflow.java:45) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.security.DefaultSecurityWorkflow.perform(DefaultSecurityWorkflow.java:60) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.parameter.DefaultPostParameterWorkflow.perform(DefaultPostParameterWorkflow.java:49) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.content.DefaultContentWorkflow.perform(DefaultContentWorkflow.java:74) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.parameter.DefaultParameterWorkflow.perform(DefaultParameterWorkflow.java:58) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.parameter.DefaultURIParameterWorkflow.perform(DefaultURIParameterWorkflow.java:92) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.scope.DefaultScopeRetrievalWorkflow.perform(DefaultScopeRetrievalWorkflow.java:50) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:130) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:65) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.cors.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:68) at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50) at org.primeframework.mvc.workflow.DefaultMVCWorkflow.perform(DefaultMVCWorkflow.java:109) at org.primeframework.mvc.PrimeMVCRequestHandler.handle(PrimeMVCRequestHandler.java:76) at io.fusionauth.http.server.internal.HTTPWorker.run(HTTPWorker.java:183) at java.base/java.lang.VirtualThread.run(VirtualThread.java:329) Caused by: java.util.zip.DataFormatException: invalid code lengths set at java.base/java.util.zip.Inflater.inflateBytesBytes(Native Method) at java.base/java.util.zip.Inflater.inflate(Inflater.java:376) at java.base/java.util.zip.Inflater.inflate(Inflater.java:470) at io.fusionauth.samlv2.util.SAMLTools.decodeAndInflate(SAMLTools.java:158) ... 37 moreUsing the Onelogin decoder tool (https://www.samltool.com/decode.php) the request seems valid and is shown below:
<samlp:AuthnRequest xmlns:samlp="urn:oasis:names:tc:SAML:2.0:protocol" xmlns:saml="urn:oasis:names:tc:SAML:2.0:assertion" ID="ONELOGIN_5d10bafc7b1602cbb1ac37c509e360e855819860" Version="2.0" ProviderName="Example" IssueInstant="2026-02-19T14:49:55Z" Destination="http://localhost:9013/samlv2/login/ee0d98b5-0d7c-11f1-8200-364d3bfc89af" ProtocolBinding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST" AssertionConsumerServiceURL="http://localhost/saml/acs"> <saml:Issuer>http://localhost/saml/login</saml:Issuer> <samlp:NameIDPolicy Format="urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified" AllowCreate="true" /> </samlp:AuthnRequest>In SuiteCRM I am following the directions in the manual here:
[https://docs.suitecrm.com/8.x/admin/configuration/saml/8.7.0-saml-configuration/](link url)If anyone has any ideas what I am doing wrong?
Thanks.
Configuring SMTP settingsposted in Q&A
Hello,
We have been using fusionauth for a while now but not utilised the email features for passwords etc.
fusinauth is running as a docker instance on an IONOS server.
I am trying to setup the SMTP settings as per the mannual and get the error when testing with the test button:
I have tested the SMTP server configuration using the swaks tool as reccommended by many posts on the forum with a successful reply using this command:
swaks --to mymail@address --from another@address --server smtp.office365.com --port 587 --auth LOGIN --auth-user <my_username> --auth-password <my_password> -tls
I have checked with IONOS that the ports 25 & 587 are actually open.
Not sure what else it could be. Does anyone have any ideas?
