    2. kevin.mahoney
    K
    • Topics 0
    • Posts 3
    • Best 1
    Posts made by kevin.mahoney
    • RE: Does FusionAuth support high availability database configurations?
      @dan 160ms
      posted in Q&A
      K
      kevin.mahoney
      @dan thanks for the response - yeah we are performing load testing currently and FusionAuth is performing excellently. For reference we've got it running containerized on 1 core of an amazon c6a.large instance, with about 1700mb memory, and getting 60 registrations per second, p50 response time of 65ms.
      posted in Q&A
      K
      kevin.mahoney
      @dan there's one important case not covered in those docs - a high-availability database configuration with a single write-instance and one (or many) read-instances (or replicas.)
      Does FusionAuth support this? Typically support means that read-only queries are routed to this read-replica by the application, in order to reduce querying load on the primary write instance.
      posted in Q&A
      K
      kevin.mahoney
