Hi @dan, thanks for your answer. In our case, we are accessing directly to the FusionAuth instance and we started to get this error after the last upgrade to 1.36.8.
I will fill an issue.
Thank you very much,
regards
regards
Hi, we have upgraded to latest version available at this moment, 1.36.8, and now we are getting a javascript error when trying to log with a Google account. You could see this error at the console just when you load the administrator login page:
This happens when you load it for the first time and your browser cache is empty. After that moment, sometimes it loads or not.
We use another theme for a different tenant and we managed to fixit adding the load of Helper.js script file:
[#macro alternativeLoginsScript clientId identityProviders]
<script src="/js/identityProvider/Helper.js?version=${version}"></script>
[#if identityProviders["Google"]?has_content]
<script src="https://apis.google.com/js/api:client.js"></script>
<script src="/js/identityProvider/Google.js?version=${version}" data-client-id="${identityProviders["Google"][0].lookupClientId(clientId)}"></script>
[/#if]
[/#macro]
Regards
