We purchased a starter license and currently use Fusion Auth 1.44.0
Starter license comes with Advanced MFA
Setting up the MFA policy in the tenant works fine, every app will use the MFA tenant policy.
According to the docs you are able to overwrite tenant MFA config per application.
When trying to make any changes in the tab MFA or advanced in the application UI I get following error
Advanced Multi-Factor Authentication feature with Application configuration required
After having a close look at the docs it says you need an enterprise licence while the error nor the pricing table says that this feature is only applicable with an enterprise license.
So what is correct, is this feature only applicable to an enterprise license and is the error message a bit misleading that you need to configure something or can I configure something within the scope of the starter license?
If this feature is only available with an enterprise license why is this not listed in the pricing table when comparing all the licenses? IMO advanced MFA should also include overriding tenant config per application
