@dan Thanks for your reply
M
Posts made by muthu.tvg
Fusionauth will work in mysql enviroment?posted in Q&A
fusion auth will work MySQL environment? If yes means share the steps
RE: Not able to install fusion Auth in my local wamp server windows based machineposted in Q&A
@dan yes i can able to connect with phpmyadmin with mentioned user name but still i got the same error.
The database and schema exist, but for some reason the ordinary user you specified cannot connect to it. Perhaps the user already existed and you provided the wrong password. The error from the database was [Access denied for user 'global'@'localhost' (using password: YES)]. I have created the super admin for phpmyadmin and provided also.
Please guide me to sort out this issue,
