    2. oliver.muthusami
    O
    • Topics 1
    • Posts 1
    • Best 0
    Posts made by oliver.muthusami
    • Use Microsoft Graph API with FusionAuth entra login
      Hi,
      Version: 1.61.1
      I have implemented FusionAuth with Azure Ad (Entra Id) to my application and I am able to successfully sign in to my app using my Microsoft account.
      In this guide, it states that FusionAuth will have an Azure AD authorization code which can then be used to get an Azure AD access token:
      https://fusionauth.io/docs/lifecycle/authenticate-users/identity-providers/enterprise/azure-ad-oidc.
      I haven't been able to find a way to get the azure ad token from the logged in user to then use it to access the Microsoft Graph API. I can only get the FusionAuth access and Id tokens which don't work with Microsoft Graph.
      How can I achieve this/is this possible?
      posted in Q&A
      O
      oliver.muthusami
