@dan I have a Java Rest API. How to authenticate the APIs using generated tokens? What are the steps?
We need to pass the token in the API header as Authorization: Bearer<token> But what is the process so that I can validate the endpoint with the valid token if the token is invalid or does not have the required roles or scope then I should get 401 else I should be able to access the API successfully.
