    2. tiny.lamp6590
    T
    • Topics 1
    • Posts 5
    • Best 2
    Posts made by tiny.lamp6590
    • RE: React SDK - Architecture
      @david-toon-fsd I think that is where I am headed next, thanks for the heads up on cookies. I finally got the their fusionauth-example-react-sdk working with self hosted non-docker and cookies were part of the problem.
      My main goal is to figure out how to use my own login forms, etc and not have to deal with creating and matching my styling with their hosted forms even though they recommend it. @dan has some advice from this 2020 post if your doing the same.
      It would be great if they had an unstyled set of components so we could drop in like <FustionAuthLogin/> and send it the specified Props and integrate/style as needed. May try to create a small headless UI library down the road to do that if I ever get this all figured out.
      posted in General Discussion
      T
      tiny.lamp6590
    • RE: React SDK Example Issue
      @vinicius-campitelli Thanks for the suggestions.
      • It looks to be running v0.25.0.
      npm list @fusionauth/react-sdk
      ../FusionAuth/fusionauth-react-sdk/client
      └── @fusionauth/react-sdk@0.25.0
      • No error info in the callback url
      http://localhost:9000/app/callback?code=8qyqXxsXBAYv1i3RAjD5ecjVi05jfPSawUwi_n1Qzmw&locale=en&state=aHR0cDovL2xvY2FsaG9zdDozMDAw%3Adb93b7b1df541be08ee5b2800735992945696efa66e73fa183f26307%3A&userState=Authenticated
      • server/pkce.js is used in register.js and login.js. Following the flow with console logs of the code object being returned by pkce.js and starting from the Log In Button:
      click Login and lands on fusionAuth service route /oauth2/authorize with the following in the url
      http://localhost:9011/oauth2/authorize?client_id=21129524-908f-49e6-b6d7-435d7fe6119a&scope=openid+offline_access&response_type=code&redirect_uri=http%3A%2F%2Flocalhost%3A9000%2Fapp%2Fcallback&code_challenge=z_XjnlmOGqunLdkSO5AT6lJYsrTPTarA9oMsRLKasw0&code_challenge_method=S256&state=aHR0cDovL2xvY2FsaG9zdDozMDAw%3A78a0ad25655561244958f39e4cdaeb0eb216029ab3cbbdc9687fc0d5%3A
      From the login.js I had added the console.logs on the code returned from pkce.generatePKCE()
      router.get("/", async (req, res) => {
        console.log("accepting request for login")
        console.log(`client_id is ${req.query.client_id}`)
        const newState = redirectState.pushRedirectUrlToState(
          req.query.redirect_uri,
          req.query.state
        console.log(`newState is ${newState}`)
        const code = await pkce.generatePKCE()
        // Added Console logs
        console.log(">> login.js code: ", code)
        console.log(">> login.js code.code_verifier: ", code.code_verifier)
        cookie.setSecure(res, "codeVerifier", code.code_verifier)
        const token_exchange_uri = `${req.protocol}://${req.get("host")}/app/callback`
        console.log("Login Redirect URI: ", token_exchange_uri)
        const queryParams = {
          client_id: req.query.client_id,
          scope: req.query.scope,
          response_type: "code",
          redirect_uri: token_exchange_uri,
          code_challenge: code.code_challenge,
          code_challenge_method: "S256",
          scope: "openid offline_access",
          state: newState,
        const fullUrl = generateUrl(queryParams)
        res.redirect(fullUrl)
      and get this in the console:
      client_id is 21129524-908f-49e6-b6d7-435d7fe6119a
      newState is aHR0cDovL2xvY2FsaG9zdDozMDAw:e4f8adf6a76523e08258f2a550e6a13e2db5a853ecc54ba194cf872b:
      in generatePKCE
      >> login.js code:  {
        code_verifier: '6429ae643852c4205933d692481ef296262b19535f618a53190a7d09',
        code_challenge: '6SUGydL3h7lcE9y54xKGrzJeHsyTnN0_J8GigrFTn7g'
      >> login.js code.code_verifier:  6429ae643852c4205933d692481ef296262b19535f618a53190a7d09
      So the code.code_verifier from pkce.js has a value which is then set in cookie.setSecure as a value to codeVerifier.
      But as shown in the app/callback req.cookies.codeVerifier is undefined and is passed that way in the oauth2/token call.
      Not sure if that qualifies as troubleshooting pkce.js but now looks to be more a cookie issue?
      Looking at cookie.js both setSecure() and setReadable() use secure: true in the cookieProps and then doing a little google research on secure cookies read that
      browsers which support the secure attribute will only send cookies with the secure attribute when the request is going to an HTTPS page
      So since this is all running on http localhost the cookies probably are not sent. Changing the cookieProps to secure: false and no longer get the error!
      So solved!? BUT now it throws me back to the localhost:3000/ root path with the login & register buttons after logging in instead of to the secure /account page. And when I manually navigate to /account the isAuthenticated check routes me back to the root path. Using a timeout function to hold the page in view a couple seconds show a blank page with just the logo and a simple console.log shows isAuthenticated from the SDK is false. So new issue.
      I think I am a bit burned out on getting this to run locally, will probably eject the whole thing and retry with a clean start with only changes to the cookie security when I have the bandwidth. Thanks again for your suggestions.
      T
      tiny.lamp6590
      @dan Yes, it is still happening. I just went through it again and everything seems to check out with the setup. With console.log checks of the flow through app/callback I did find one potential issue that there is no codeVerifier in the req.cookies
      router.get("/", (req, res) => {
        console.log("accepting request for token exchange")
        // added console.log checks
        console.log("Request Cookie: ", req.cookies)
        console.log("Code Verifier: ", req.cookies.codeVerifier)
        const code = req.query.code
        const codeVerifier = req.cookies.codeVerifier
        const redirect_uri = `${req.protocol}://${req.get("host")}/app/callback`
      Console Output
      Request Cookie:  {
        'fusionauth.remember-device': 'QkJCAQFsTNi5MoJrFruNrayMfc8hu0-RyUsGyIShNODgcEAA',
        'fusionauth.sso': 'AgIoJJexUbQDN2Bmp_KPxP1i9PkO0_ItLkg9PNIbkYol',
        'fusionauth.locale': 'en',
        'fusionauth.timezone': 'America/New_York',
        lastState: '94acf860312a9d798db4049f741e764cf90da8ce65e0338d7b6715d0:',
        'fusionauth.at': 'eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCIsImd0eSI6WyJhdXRob3JpemF0aW9uX2NvZGUiXSwia2lkIjoiZmMyNGZlNTU3OCJ9.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.qdeLWlVcKfXIfRQUjdmMDs2yCHD0hVq2WIYnIXatX-w',
        'fusionauth.rt': 'CFoc15z-AiYcxcqw35cXjn7TY2wNhn43ouxy7t_qfto5dVY0wHt0fA',
        sAccessToken: 'eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsInZlcnNpb24iOiIyIn0=.eyJzZXNzaW9uSGFuZGxlIjoiMWQ5YjNhYmEtMTNmMy00YzViLWE3MDYtZWZkZGRjMzgyM2UwIiwidXNlcklkIjoiMWUwNzY0MzMtMzc1NC00MWRiLThmZTgtOTg4Mzk3YWY4MmZkIiwicmVmcmVzaFRva2VuSGFzaDEiOiJkMjBlNTM3MDE3NTQ2YzY0MWE3NTVjMzk2N2NhYzcyY2RkYzRhZGFhZGQxNjc0ZGVlYWY3ZjQ3MDQ0MzRmN2ExIiwicGFyZW50UmVmcmVzaFRva2VuSGFzaDEiOm51bGwsInVzZXJEYXRhIjp7fSwiYW50aUNzcmZUb2tlbiI6bnVsbCwiZXhwaXJ5VGltZSI6MTY4MjgyMzc3MjAyMSwidGltZUNyZWF0ZWQiOjE2ODI4MjAxNzIwMjEsImxtcnQiOjE2ODI4MjAxNzIwMjF9.Kszhn1PT5bHnIcLsKwUQ3zyV25Xy24qLwVUUeS66NlTWH1spN/UoKgP6AhMKXunucYkvT2BGArYqdFnFM4fCxhytrboTKtYaVF6OeCdAxYhladYvgz59gALKYZ2Htiq8Pi3MMQQTum8J20Ae5nSmWUQfrQlzyN5Nc6v59ugSYlNXVvdaQDbJtjjf96yUHdOn3vpGHNjBplTR68mvOEXcavMICPfaCfqMwsaxmlQtHCE30keavinPgEDZ7LclWbJk+cKI6m28yWLGe77WW89oTGJ+mCauprZDwYyVWxIS7BXLYSTgiEWiIvgQtDYbGQlUVrwDGN4pn2VL3vhEbzHzHQ==',
        sFrontToken: 'eyJ1aWQiOiIxZTA3NjQzMy0zNzU0LTQxZGItOGZlOC05ODgzOTdhZjgyZmQiLCJhdGUiOjE2ODI4MjM3NzIwMjEsInVwIjp7fX0=',
        'st-last-access-token-update': '1682820172039',
        'fusionauth.known-device.B_L9M3zcnQB5ZmkY_vZSdxt4bj7DG02aF1ur2Gle5uI': 'k1-SYySzGI1JI93fnWd70TjMhRLwXl3H_v1LJLiK03lU9qrmvj7wpT5ktEnqyB8b',
        'fusionauth.known-device.58nYCMmurFn0ZYtN8AHocKJJC4A74IkRq0McoRtcik8': 'rIk7kVrwANxWPOiUYtKIQtCWrD8FlLe0kr7MWJqEcQL3BbvVrlchLzlpEmQdLfty',
        'fusionauth.known-device.171xuqNosEvqLcUHp26t_opk4L-p4qqp1nTXNAYsnT4': 'cT_K5TflTbG6kl4W-XVFuw5pfAGl5GPNoIAxkS-bMV_pRDND_wJiIYC36NU6M99z',
        'fusionauth.known-device.HlilUTdHiTm-5g9-0E3SkStX_Vlx5HlqncVgeoz1PIE': '1qwS-PwMf-KW-puKlkbrIL9rMFkQYZwBV1KAKikbZ5MIYM5gT3UMp7C8LLNCCNqu'
      Code Verifier:  undefined
      I tried changing the app OAuth setting for PKCE to required and still no codeVerifier was undefined nor any change in behavior. In the request it sent as undefined in the form.
        request(
          // POST request to /oauth2/token endpoint
            method: "POST",
            uri: `${config.fusionAuthBaseUrl}/oauth2/token`,
            form: {
              client_id: config.clientID,
              client_secret: config.clientSecret,
              code: code,
              code_verifier: codeVerifier,  // undefined
              grant_type: "authorization_code",
              redirect_uri: redirect_uri,
            headers: {
              "Content-Type": "application/x-www-form-urlencoded",
      The docs seem to indicate that code_verifier is optional if a client secret is used and I have triple checked the id and secret are properly set and being sent from the config.js as well as matching the Application OAuth settings in the dashboard. The only other thing is the redirectURL which is sent as http://localhost:9000/app/callback.
      Any ideas on what I may have missed or should check next? Thanks~
      T
      tiny.lamp6590
      @david-toon-fsd
      I am testing out React & FusionAuth as well and so far for the login/registration it looks like you need to go through a communication server like Express for the token and auth. But with the SDK once logged in you can use a provider context and hooks to check authentication state. Check out their fusionauth-example-react-sdk
      the Provider from the src/index.tsx
      root.render(
          <React.StrictMode>
              <BrowserRouter>
                  <FusionAuthProviderWithRedirectHandling>
                      <App />
                  </FusionAuthProviderWithRedirectHandling>
            </BrowserRouter>
        </React.StrictMode>
      and a hook for getting Auth state from the AccountPage.tsx
      const { user, isAuthenticated, isLoading } = useFusionAuth();
      But I think I have some of the same general questions as you, such as I would like to use my own integrated React-Tailwind styled login form to send credentials rather than having to use and theme theirs to try to match my app. And do I have to use their provide Login Button to link to their login form or is that just for convenience?
      <FusionAuthLoginButton className={styles.button} />
      T
      tiny.lamp6590
    • React SDK Example Issue
      I am testing out FusionAuth for using in React and trying to implement the FusionAuth example for React using the FusionAuth React SDK:
      I have FusionAuth running on my dev machine and followed the instructions in the REAME. Everything seems to be setup as instructed and double checked but when attempting to login the app/callback route responds with service unavailable and the console message:
      refresh token or access token is missing.
      {"error":"invalid_request","error_description":"Invalid Authorization Code","error_reason":"auth_code_not_found"}
      Through various console.logs I have checked all the form field variables posted to the /oauth2/token route and they seem correct but the response body only has the error object, no tokens.
      Searching around I have seen issue with the redirect_uri and the setup in the FusionAuth Application but again they seem properly setup and matching. I am assuming I am missing some key setting but have rechecked the README instructions and the Application setup multiple times without success so at this point any suggestions I should checkout would be much appreciated!
      T
      tiny.lamp6590
