    2. wc-fa
    W
    • Topics 1
    • Posts 1
    • Best 0
    Posts made by wc-fa
    • Can You Limit a User's Login/Authentication Access to Applications within a Single Tenant?
      The product is great, but I appear to be missing something fundamental about the solution's use case.
      I have a single Tenant with four (4) Applications and ten (10) Users defined. I want 3 users to have login access to all four Applications, and 7 users to have login access to only of the 2 applications. However, it appears that anytime I add a user to the Tenant the user receives "login/authentication" rights to all 4 applications.
      Before installing and setting-up FusionAuth, I thought I would be able to use the "Groups" feature to create a group called "Group-A" that would "grant" login access to all 4 applications and another group called "Group-B" with "grant" login access to only 2 applications. I would assign the 10 users to either Group-A or Group-B and limit which user could login/authenticate to a particular application.
      This does not capability does not appear to exists. What am I misunderstanding?
      posted in Q&A
      W
      wc-fa
