    2. zero-enna
    Z
    • Topics 1
    • Posts 2
    • Best 1
    Posts made by zero-enna
    • RE: FusionAuth as oidc provider for apache2
      I found the solution by my self.
      After several debugging, trial-and-error session and minimal setup's I could solve the issue.
      I found the final hint here:
      https://fusionauth.io/docs/v1/tech/oauth/endpoints/#json-web-key-set-jwks
      FusionAuth did not create asymetric key's in default, so I have to create a new asymmetric key that can be validated at the JWK endpoint by apache2.
      Zero
      posted in Q&A
      Z
      zero-enna
    • FusionAuth as oidc provider for apache2
      Hi all,
      I have tried to use FusionAuth as an OIDC provider for apache2 but it didnt wokred well at the moment.
      I have set update the default installation for FusionAuth like describte here https://fusionauth.io/docs/v1/tech/installation-guide/fusionauth-app/ with an mysql database. My first trial with gitea run very good. I could set up it in a few minutes and it works well.
      Now I would like to secure an third-party software without an login and would like to use the apache as an reverse proxy with the mod_auth_openidc module. The Application runs wihin its own sub-domain.
      I have tried a lot of configurations for apache2 and fusionAuth but it didnt work well. Did you have any working example configuration for apache with FusionAuth?
      Zero
      posted in Q&A
      Z
      zero-enna
