    SAML invalid timestamp.
    6
    8.9k
      joseantonio
      Hi!
      Situation:
      Few months ago my I set up a FA installation hosted in FA servers. Then I set a SAMLv2 IDP configuration, and in the end ran perfect.
      Now I set the same configuration for the same IDP in a FA installation (1.27.2) hosted in our servers.
      However, this configuration does not work correctly this time. I have contacted the IDP manager, and he said that the timestamp in the AuthNRequest is invalid. So, I checked the server and database timezone configurations, and set everything to UTC, as SAMLv2 demands, and then rebooted everything. No effect from this.
      Then I realized that the event logs in the FA server shows a different time (UTC) from ours (CEST).
      FA hosted server:
      Our server:
      Do you have any ideas on how I can change or set that timezone? Since I think this is the reason why the SAML conection is not working.
      Thank you!
        joseantonio
        Hi again!
        For the record, I just found the solution.
        Fusionauth config is taken from JVM variables, as explained here. These can be chaged with the fusionauth-search.additional-java-args property, specified in the fusionauth.properties file like so:
        fusionauth-search.additional-java-args="-Duser.timezone=UTC".
        Then everything is working and compliant with SAMLv2 timestamps. Hope this helps someone else some day.
        ? 1 Reply Last reply Reply Quote 1
          A Former User @joseantonio
          @joseantonio
          Thanks!! This may be a bug, we’ll open an issue to track.
            dan @A Former User
            @joseantonio
            We opened a bug and reviewed our SAML code and were unable to replicate the issue.
            Here's the bug: https://github.com/FusionAuth/fusionauth-issues/issues/1486
            If you can add any replication steps or other information to this bug, that would be very helpful. Otherwise we'll close it out in a week or so.
            J S 2 Replies Last reply Reply Quote 0
              joseantonio @dan
              Hi @dan !
              I'm sorry, the only thing I can say is that setting
              solved the issue for me.
              If that's already solved, I guess it can be closed.
              Thanks @dan and @robotdan for reviewing issues!
              • S
                summercurrants @dan
                @dan said in SAML invalid timestamp.:
                @joseantonio
