    Endless redirects when using the spring example and a fusionauth cloud instance
    1.0k
      Working through https://fusionauth.io/blog/2023/01/03/spring-and-fusionauth, it works fine when running locally, but when running with a FusionAuth cloud instance (or on any remote server), I get stuck in endless redirects after logging in.
        dan @dan
        I was able to recreate the "too many redirects" issue on my end. I received a couple of errors that I was able to resolve and get the app working.
        The first error was this: Unable to convert claim 'iss' of type 'class java.lang.String' to URL.
        To fix this I made sure the issuer value on the Tenant level was a full URL (e.g. https://fusionauth.io instead of fusionauth.io).
        The next error I ran into after that was this: Missing attribute 'name' in attributes.
        To fix this one I just needed to make sure the user had a Full Name value on their profile. The default OIDC integration requires that.
