    Does FusionAuth provide pre-built components?
    4.2k
      A Former User
      Instead of forwarding over to the oauth endpoint to login does FusionAuth have pre-built components similar to Clerk's components?
        A Former User
        We don't offer UI components at this time, but you can build your own using our Login APIs. In order to create and register users, you can also use our Registrations API.
        • System has marked this topic as solved on
          dan @A Former User
          It's also worth noting that we strongly recommend using the Authorization Code grant and redirecting to FusionAuth's hosted login pages, rather than using the Login API.
          This has the following benefits:
          • you don't have to worry about any other architectural components handling credentials, which are highly valuable to an attacker
          • this solution works across almost all mobile and web applications, whether custom or COTS or OSS, as opposed to being limited to React SPAs
          • you get FusionAuth's app to app single sign-on
          • when there is a new workflow added, implementing it is a matter of configuring FusionAuth correctly rather than modifying your code to add a new component; an example would be adding a social provider or magic links
          We understand that this sometimes comes at a cost of UX complexity as you need to sync or at least align your UX between two different systems. This is why we offer the Login API as @Alex-Patterson mentioned; it's an escape hatch if redirecting just won't work.
          We also have themes to support customizing the FusionAuth hosted login pages, including this example which uses Tailwind.
